8
What are the main advantages of using breadboard instead of PCB?
Works great for quick prototypes using through-hole resistors, capacitors, and DIPs with 22ga solid-core copper wire.
You need to be aware of the disadvantages though.
  • not meant for withstanding high voltages (don't plan on anything above 48V)
  • not meant for carrying high currents (I'd consider anything over 20mA questionable and anything over 100mA objectionable)
  • high parasitic inductance and resistance
  • high parasitic capacitance between adjacent rows
The last two are issues with high bandwidth circuits; don't expect to send around 10MHz analog signals easily. One way of getting around it a little bit is for sensitive signals to use every other row and ground the in-between rows. (this is somewhat like using a guard ring) This also works well for reducing unwanted Miller capacitance e.g. between base and collector pins of a bipolar transistor.
| improve this answer | |
You can re-use breadboard and move components/connections around to try different things.
That's about it really. Flexibility to experiment.
  • It is reusable.
  • This makes it easy to use for creating temporary prototypes and experimenting with circuit design.
  • A variety of electronic systems may be prototyped by using breadboards, from small analog and digital circuits to complete central processing units (CPUs).
  • These are typically high-quality breadboard modules mounted on a flat casing.
  • The casing contains additional equipment for breadboarding, such as a power supply, one or more signal generators, serial interfaces, LED or LCD modules, and logic probes.
