I wanted to know exactly how does bluetooth sniff mode work. Is this special mode going to affect data rates?
Is it used in active transmissions or in idle mode? I am a bit confused.
  • \$\begingroup\$ Please post documentation. Where did you read the term? \$\endgroup\$ – Robherc KV5ROB Mar 5 '16 at 13:04
To know all the details you might want to read the this document. Beware that that documentation is extremely technical as it is intended for communications and system engineers.
But in a nutshell:
  • No sniffmode will not influence the datarate as it is not used while transferrig data to the device.
  • It is used in one of the idle/sleep modes when no active communications is ongoing.
  • Snifmode is used to see what other devices are active within the area.
