I want to add a factory reset onto a PCB design I am working on. Basically, I want it to be a switch (or combination of) that will never be "accidentally" closed and therefore accidentally factory reset the uC.
My initial thought was to add a switch you can only press with a needle that you see often in consumer products, except this PCB will not be inside an enclosure and I believe the "needle" requirement comes from designing the enclosure to have a small opening that only a needle can penetrate.
My next idea is to use an 8PDT switch (or similar) where only 1 combination of the 8 switches (1 / 2*8 = 1/256 = 0.4%) will output a "1" to the factory reset.
Anyone have any experience with this, or suggestions for alternate methods?
Thanks.
  • \$\begingroup\$ Make it like that game Simon Says! \$\endgroup\$ – Keegan Jay Mar 8 '16 at 17:28
  • \$\begingroup\$ By "8PDT" do you mean an 8-position DIP switch? Because an 8PDT switch is just a two-state device. \$\endgroup\$ – rdtsc Mar 8 '16 at 18:25
  • \$\begingroup\$ Yeah, meant a DIP switch where each could be switched independently. Good catch. \$\endgroup\$ – Jim Mar 8 '16 at 19:22
Use a standard PCB button, but require the user to press it in a sequence that would not happen accidentally.
For example: 1 long press, followed by a long release, followed by a short press. The long press and release could be 2 seconds each, the short press could be 0.5s. Obviously you have to allow for a tolerance on these timings.
Or, press the button 3 times within a certain time interval, etc.
  • \$\begingroup\$ I like it a lot, but we'd like to keep the majority of the processing in hardware and I think setting up this timing circuitry may be tough. If we decide to include software algorithms to determine the "intention" of the button press, this seems like a very elegant solution. \$\endgroup\$ – Jim Mar 8 '16 at 19:24
Ideas:
  • Use a standard PCB button and check for status immediately after power-up reset. If button is pressed then perform the factory reset. Note that if the button is jammed for any reason that a factory reset will occur.
  • Use a 20 s hold-in. Netgear use this approach on many of their SOHO routers. With this approach you can check that the button is open on power-up and subsequently closed for 20 s. The long time delay is unlikely to be reached by someone just probing about.
  • \$\begingroup\$ Thanks! I like the 2nd idea a lot, especially since it seems pretty simple to implement in hardware. \$\endgroup\$ – Jim Mar 8 '16 at 19:27
I've seen people use a relatively inaccessible push-button (paper clip or must open case to access) that is held down during power-up.
That ensures enough intention that it won't get accidentally triggered, IMO.
