I'm trying to debug code on an 8 bit AVR microcontroller (Atmega328P) via debugWIRE using AVaRICE, avr-gdb and the JTAGICEmkII debugger.
I'm doing the following steps:
Compile the code with g2 debugging info in stabs format with no optimizations:
avr-gcc -Wall -g2 -gstabs -O0 -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega328p -DF_CPU=1000000UL
Create hex:
avr-objcopy -R .eeprom -O ihex lambda.elf lambda.hex
Upload hex:
avrdude -pm328p -cjtag2isp -B10 -Uflash:w:lambda.hex:a
Start AVaRICE:
avarice -2 -w -B10 -j usb :4242
AVaRICE version 2.11, Jan 17 2014 02:51:59
JTAG config starting.
Found a device: JTAGICEmkII
Serial number: 07:00:00:00:5c:3c
Reported debugWire device ID: 0x950F
Configured for device ID: 0x950F atmega328p
JTAG config complete.
Preparing the target device for On Chip Debugging.
Waiting for connection on port 4242.
Start avr-gdb:
avr-gdb lambda.elf
Reading symbols from lambda.elf...done.
(gdb) target remote localhost:4242
Remote debugging using localhost:4242
0x00000000 in __vectors ()
Set a breakpoint inside the main loop in main()
(gdb) break lambda.c:74
Haltepunkt 1 at 0x2ae2: file ../lambda.c, line 74.
And contiune, hoping for the program to stop at the breakpoint:
(gdb) continue
Continuing.
The program starts fine but never stops. I can stop it with CTRL+C:
^C
Program received signal SIGINT, Interrupt.
0x00002d2e in getTime () at ../interrupts.c:51
51 time = ints >> 5;
What puzzles me then is that if I look at the debug info dumped with
avr-objdump -g lambda.elf > debug.txt
at the same line of code, there is another address:
/* file ../interrupts.c line 51 addr 0x2d10 */
and even if I set a breakpoint at exactly that address 0x00002d2e where the program was interrupted (function getTime() is called repeatedly):
(gdb) break *0x00002d2e
Haltepunkt 2 at 0x802d2e
the program will never stop - and why is the breakpoint set at 0x802d2e?
Is it normal that the addresses don't match or could this be the reason for the breakpoints not working? Do I need to set some address offset?
Originally I tried to debug from Eclipse with the avr-eclipse plugin, and it shows the exact same behaviour, which I guess is not surprising since it uses the same tools behind the scenes.
