So I am working on: http://www.nand2tetris.org/ and I am having a hard time understanding the D-Flip Flop, or maybe I should say, how Logism represents it.
I have this circuit and this is the current state I am in. The D Flip-Flop I have in my circuit has the property Trigger: Falling Edge.
Now I will click on load and in inputs: enter image description here
And I will tick once enter image description here
At this moment, it is ok that out = 0. I can understand it. However, my expectation is D should already be loaded, and should be showing 1, not 0.
Only after I tick one more time, I the D will be loaded: enter image description here
If I cover the value shown by D, everything makes sense, how the Flip Flop works etc.. But as long as I am seeing the value in the D - Flip Flop itself, I get confused.
Is my understanding wrong or something wrong with Logisim?
  • \$\begingroup\$ Your description actually shows the behaviour of a rising-edge triggered flip-flop. Also the schematic symbol also shows a rising-edge clock input. Are you sure, that you have falling-edge triggered flip-flop? \$\endgroup\$ Mar 12, 2016 at 18:32
  • \$\begingroup\$ @MartinZabel I have exported the xml file here: pastebin.com/4Ety53ic There you can also see: <a name="trigger" val="falling"/> \$\endgroup\$ Mar 12, 2016 at 18:54
What you're running into here is a quirk of Logisim. Each simulator "tick" is resulting in half of a clock cycle, not a whole cycle. (You can see this in the screenshots: the clock input goes from dark green to light green after the first tick, and back to dark after the second tick.)
Since the D flip-flop is set to trigger on the falling edge of the clock, the output only updates after the second tick because that tick is the one in which the falling edge occurs.
Hooking the clock input up to another digital input (like you've got for "load" and "in") may make it easier to play around with this circuit.
  • \$\begingroup\$ Thank you for your response. However I am already expecting that the D will turn to 1 in "half cycle" already. \$\endgroup\$ Mar 14, 2016 at 4:41
