Background
I am using a TI LM2776 Switched Capacitor Inverter (datasheet here) to obtain a -3.3v bias voltage for an LCD (Newhaven Display, NHD-12864MZ-FSW-GBW-L, datasheet here).
The LM2776 is connected exactly as shown in this digram from its datasheet:
Vin is 3.3v, EN is connected to Vin, and I'm using the same capacitor values.
Question
When I turn on the circuit with no load, the output of the LM2776 is about -0.9v. When I connect it to the LCD bias pin to load it, the output is about -0.7v. Why am I not seeing about -3.3v?
Other Notes
LCD Load
When I connect the LCD bias voltage pin to a DC power supply (at -3.3v) instead of the LM2776, the LCD draws about 20mA, so the LCD should be an appropriate load for the LM2776. According to the datasheet, I shouldn't be seeing any significant voltage drop at this current draw:
Capacitors
All capacitors are ceramic X7R radial capacitors.
Layout
The circuit is currently on a breadboard, and the LM2776 is connected to it through a SOT23-6 -> DIP adapter. I know these devices can be sensitive to layout considerations, but the same configuration worked a couple of weeks ago, and I have no reason to suspect there was damage of any kind done to it since then.
