The CT types I'm thinking of are those used for the general monitoring of household currents. Myth or truth, will a regular CT (in an otherwise normal and suitable current monitoring situation) generate thousands of volts on the secondary if the burden is removed?
A CT is a step up transformer and the biggest turns ratio I've come across is 5000:1 so potantially, with 200 mV AC on the input, the output could be a thousand volts. But how easy is it to generate 200 mV RMS at 50/60 Hz on one primary turn? The inductance of the short length of cable that passes through the core is going to be in the micro-henry range and, at 60 Hz, 10 uH has an inductive reactance of 3.8 milli ohms. That implies a current of about 53 A is needed. This is significantly above most household circuits of course.
For most small CTs (I'm thinking ones that are used for AC household current monitoring) if the burden is removed, the core is very likely to saturate and this means magnetization inductance falls down to tens or hundreds of nano henries. The knock on effect is that you might generate a few tens or maybe a hundred volts on the output.
So, is this an urban myth or can regular CTs used for monitoring household AC currents potentially produce thousands of volts when the burden is removed from the secondary?
