I have a small touchscreen hooked up to a Raspberry Pi, powered by (and getting ethernet connectivity from) a 802.11af splitter. Everything basically works.
Sometimes when I first walk up to the (capacitive) touchscreen, it behaves oddly - phantom touches, a bit of a 'static-y' feel as my finger gets close to the screen, etc. It usually goes way if I touch the screen (even the edge) and leave my finger there for a few seconds. I'm wondering if it could be caused by a grounding issue.
Should I be connecting the ground on my Pi to the in-wall conduit in addition to the ground wire coming from the POE splitter? Or would that just cause more problems?
Most probably it is not a device charged, it is you who is charged. Look for the cause of charge around you: your clothing, carpet, material of your sofa... If device would be charged, when you touch it, you would synchronize with it very quickly. Here you say you need to wait for several seconds to level the charge - for me it means extended charged surface with limited resistance and high capacitance - which is you...
Update: Capacitive touch screens are widely used in handheld devices, and these devices are usually not connected directly the protective ground, and user usually touches chassis of the gadget before touching the screen.
The issue you raised is not only about proper operation of your touchscreen, but also lies in the domain of human safety. If you let user touch grounded chassis of the screen, or step onto the metallic plate with bare feet, it may cause shock or at least unpleasant feelings if user will appear highly charged (e.g. due to natural reasons - wearing wool clothing).
What I would start with is to make metallic plate around the screen, and connect it to device's protective ground using circuit similar to shown here http://www.ti.com/lit/an/snoa464c/snoa464c.pdf on page 16 near "Bob Smith termination" text, or just put 2kV 1000pF capacitor between this plate and protective ground (as it is designed in integrated RJ-45 jacks without PoE) - to the ground wire of splitter as you proposed. Then, I would require users to touch this plate before they touch the screen.
In general you should take care about proper grounding of all devices in your environment (where possible), so that there would be no cases when user touches two devices with different grounding or potential, or touching grounded and ungrounded devices.
  • \$\begingroup\$ The intended use of this device is something that's mounted on the wall (all cables hidden thanks to POE behind it), and people walk up to the device, and interact with it briefly (click a button or two). How would you suggest a deal with this? Put a large metal plate on the floor for the user to stand on and ground that? Understanding what's not grounded helps some, but I still don't know how to fix it :) \$\endgroup\$ Oct 3, 2016 at 13:18
  • \$\begingroup\$ Thanks for the suggestion - now to incorporate the plate into the physical design and make sure it's arranged that the user will naturally touch it to steady their touch while using the device. \$\endgroup\$ Oct 11, 2016 at 4:31
PoE devices should be isolated, because the injector and the device may not necessarily share a common ground reference (they might be in different buildings served by different substations, for example).
This means that without any earth connection, the device will be a floating electrode, similar to a doorknob, and behave the same way, for an ideal PoE device.
The isolation is usually achieved with a transformer, fed with a chopped DC signal, and on the secondary side, the resulting choppy AC is again rectified. Depending on the setup, this process may have a bias as well, building up a small charge.
