This question has several parts. I ordered this pull string operated flashlight --- http://bit.ly/t1lZF1 --- which charges this coin cell battery --- 3.6 V lir 2450 lithium ion battery 120 mAh ---
Like these
The battery is charged by the pull string. There is a switch which uses this battery to power three LEDS.
I want to use this battery to power something with a higher amperage rating (ideally a cell phone).
I am wondering first whether it's possible to connect these coin cell batteries in series to get a 3.6 V output @ 1080 mAh.
Next, would I have to charge them all individually in their respective pull string charger circuits and then connect the charged batteries to achieve the higher amperage?
Lastly, I wonder if I could replace the coin cells with another Li-ion battery that outputs 3.7 volts at 1000 mAh.
My guess is that that is a dumb question as both battery types require a different charging circuit, and that my best bet is to connect them after they're charged.
Hopefully someone can shed some light, thank you so much, M
Lithium Ion battery charging using a "pull-string" charger:
The charger is potentially usable but it would take a considerable time to charge a 1000 mAh LiIon battery - probably 8+ hours - see below.
Lion battery energy is > 4.2V x1000 Ma or about 4 Watt hour. Very approximate.
Combining batteries:
  • In a series string, voltages add and mAh is that of the lowest capacity battery. ALL batteries should be identical and initially at the same state of charge, and 'balancing' may be required during use.
  • In parallel: ALL batteries MUST have the same voltage and all should be identical. Voltage stays the same and mAh sums. While it is technically possible to combine batteries of different mAh capacity this will lead to sorrow of one sort or other, or several sorts at once. Combining batteries in parallel by direct connection provides no means to control the amount of current flow in or out of individual batteries and "bad things can happen".
Hand powered charging:
Based on measurements that I have made:
  • A good plastic* Chinese hand crank LED light charger will make 1 Watt continually with the user being the limiting factor. At that level it takes much effort. Operation for say 10 minutes is "very annoying" and beyond 10 minutes only the most enthusiastic would persist. (* plastic gears and case as found in many such products)
  • A properly built hand crank can return 5 x as much with less effort. Say 5 Watts continuous with relative ease or as much as 10 Watts continuous if a user is enthusiastic. 20 Watts for short period is doable by hand (or arm) but not for long for most people. This is with a direct drive alternator with no gearing and optimised for low speed use.
  • For comparison, a good quality foot / leg powered alternator can provide 50 Watts from most users over say 1 Hour without too much annoyance. 100 Watts for one hour is doable but you would preferably be fit. MUCH more than 100 Watts is possible for short periods if you are a fit athlete but for most people the above levels represent realistic levels.
"Real world" hand driven charger: I experimented with a hand driven charger using a Fisher & Paykel "Smartdrive" washing machine motor. These would probably make about as good a hand powered alternator energy source as anything that could be built. Speed of operation lies in the optimum range for comfortable use, efficiency is reasonable, the annoying force and load fluctuations and noise produced by small geared units is wholly absent. There is a small amount of low speed "cogging" or salience at extremely low speeds but this is essentially unnoticeable in use. Saliency can be reduced by pole profile modifications (with a grinder!) if desired.
These are 3 phase brushless dc motors rated at hundreds of Watts input power as a motor or output power as an alternator at design speeds. When operated by hand power at speeds in the one to few revolutions per second speed range outputs of say 5 to 30 Watts is possible at voltages of maybe 5 to 20 volts. Vout varies with wiring configuration and speed and available power at a given speed can be increased by changing the ferrite magnets to higher flux rare earth magnets. This is unlikely to be worthwhile in hand powered applications.
A pull string unit will make less power than a hand crank due to the intermittent nature of the power input. The awkward arm angle during part of the stroke unless you fasten it somehow and position it optimally will not help.
I have not measured one but guestimate upper sensible continuous output at say 500 mw.
  • 4 Wh/0.5 W = 8 hours to charge :-(.
You'd need to place about 8 x 2450 LiIon in PARALLEL (not series) to get 1000 mAh but this would be "extremely unwise" (at best).
Better is to use 1 x 1000 mAh LiIon as you suggest.
Controlling charging: If a "real" charger such as the F&P alternator based one was used a small battery could easily be destroyed. Typical consumer goods LiIon batteries intended for phones and similar are usually rated at from C/2 to 1C charge rates. ie a 1000 mAh battery at 1000 mA charge = 1C, and at 500 mAh charge = C/2. At 10 Watts the F&P charger would provide about 2.5A if the voltage was matched to the cell. In practice Vout would probably be in the 5 - 20 Volt range. Use of a properly designed charger using a buck converter and proper battery management would be essentially essential. An F&P alternator and properly designed charging unit would be able to charge a suitably specified 4.2V, 3000 mAh 18650 cell in about an hour, hand-energy-inputter willing.
Charge regulation by existing equipment:
The existing charger MAY regulate the charge properly but this is unlikely.
Look to see if it has a charge control IC.
Look to see if it has a voltage regulator to limit overcharge.
You are unlikely to get overcharge with pull string charging and a 1000 mAh battery :-) - but the PV panel will charge the LiIon 1000 mAh fully if left long enough - which may take 1 to 2 weeks of all day sun based on what they say.
A LiIon battery MUST have its peak charge voltage limited to 4.2V or less.
4.1V is safer.
MUST!!!
If you do not do this the battery may die either with a whimper or with an enthusiastic fire show. REAL magic smoke.
There are other things you can do, but limiting Vmax is probably a very very good start in this case.
NEVER run a LiIon battery below about 3V when discharging.
Doing so may destroy it.
Slightly lower than that WILL destroy it.
Testing:
Disconnect battery.
Connect voltmeter across alternator (or rectified DC.)
Operate string charger enthusiastically and measure voltage.
Repest with solar panel in full sunlight.
If either gives > 4.3V you MUST regulate.
If neither gives > 4.2V then you MAY consider not regulating. But ... .
If you can prevent it discharging below 3V it will help it live long, if not actually prospering.
