When i tried to code the below flip flop, the program failed. I'm using altera .
module DFF_SYNC_RESET(Din, nRst, Dout, Clk);
output Dout;
input nRst,Clk,Din;
wire D;
assign D= Din & nRst;
always@(posedge Clk)
 begin
  Dout<= D;
end
endmodule
Can you please tell my failure in the code? enter image description here
Edit: After i encountered to another problem which is the same as in this page, the problem was solved
https://stackoverflow.com/questions/25832326/altera-quartus-error-12007-top-level-design-entity-alt-ex-1-is-undefined
  • \$\begingroup\$ You should make D a wire and use a syntactically correct assignment likeassign D = Din & nRst;. \$\endgroup\$
    – andrsmllr
    Mar 15, 2016 at 13:19
  • \$\begingroup\$ thanks. I did but this time it threw these errors \$\endgroup\$ Mar 15, 2016 at 13:24
  • \$\begingroup\$ "DFF_SYNC_RESET cannot be declared more than once". You have more than one module with that name in your project \$\endgroup\$ Mar 15, 2016 at 13:33
  • \$\begingroup\$ this time it threw another error.left hand side of assignment must have a variable data type. thanks anyway, if the code seems okey, it is okey. i'll ask this to the lecturer \$\endgroup\$ Mar 15, 2016 at 13:45
  • \$\begingroup\$ @"DFF_SYNC_RESET cannot be declared more than once": Do you include this file in other files? The new error is quite clear, there is another module with the same name defined elsewhere in your design. \$\endgroup\$
    – andrsmllr
    Mar 15, 2016 at 15:57
In Verilog, if you assign to something in a procedural block (a block between begin and end), you need to make it a regsiter type. If you assign to something in a continual assignment (either an assign statement or the output of an instance of a module) you need to make it a wire type.
So you need to declare (You already edited this change into your question)
wire D;
on line 5, and
output reg Dout;
on line 2.
Also, D is somewhat superfluous. You could just have
output reg Dout
always @(posedge clk) begin
    Dout <= Din & nRst;
end
Even better, you should not use logic to simulate control features on flip-flops if your architecture makes full-featured flip-flops available. To code a DFF with syncronous reset for synthesis you would rather have
    if ~nRst
         Dout <= 1'b0;
    else
         Dout <= Din;
end
This will be more likely to use the built in features of the flip-flops in your architecture, resulting in faster and more resource-efficient implementation.
The error you showed doesn't seem to relate to how you defined your DFF_SYNC_RESET module. More likely it has to do with what files you are including in the synthesis or where you instantiated it, either in your testbench or in a higher-level module.
