The input to a L.T.I. circuit is \$x(t) = 6\cos(t)\cos(3t)\$, and the impulse response of the circuit is $$h(t) = \frac{\sin(3t)}{3t}$$ Obtain an explicit expression for the output y(t) as a function of time. The fourier transform of \$x(t) = \$
$$\sum_{n=-\infty}^\infty C_n e^{in2t}$$
I converted \$h(t)\$ to $$H(iw) = \frac{\pi}{3}\times\text{rect}\left(\frac{w}{6}\right)$$
However, I am confused on how I would use Fourier series coefficients to solve this problem.
