I created a module that first sorts a byte array then choose last element as minimum.(just for practice). When I moved sort to the task block, it doesn't worked as well as before. How can use task block properly for sorting ? thanks.
Sort without task:
    module sort(input clk, input nrst, output byte choose);
    byte sorted[0:3];
    assign choose = sorted[3];// output must be minimum after sort (12)
    always@(posedge clk, negedge nrst) begin
        if(nrst == 0) begin // initialize to something
            sorted[0] = 17;
            sorted[1] = 12;
            sorted[2] = 23;
            sorted[3] = 21;
        end
        else begin
            int i, j;
            byte tmp;
            //sort
            for(i=0; i<4; i=i+1)
                for(j=0; j<4; j=j+1)
                    if(sorted[j] < sorted[j+1]) begin
                        tmp = sorted[j]; // swap
                        sorted[j] = sorted[j+1];
                        sorted[j+1] = tmp;
                    end
        end
    end
endmodule
Sort with Task:
    byte sorted[0:3];
            sorted[0] = 17;
            sorted[1] = 12;
            sorted[2] = 23;
            sorted[3] = 21;
        end
        else begin
            sort_task(sorted);
        end
    end
    task sort_task(inout byte list[3:0]);
        begin
            int i, j;
            byte tmp;
            //sort
                    if(list[j] < list[j+1]) begin
                        tmp = list[j];
                        list[j] = list[j+1];
                        list[j+1] = tmp;
                    end
        end
    endtask
endmodule
Testbench:
module tb();
    byte choose;
    reg nrst, clk;
    sort sort(clk, nrst, choose);
    initial begin
        clk = 0;
        forever #5 clk = ~clk;
    end
    initial begin
        int i;
        nrst = 1;
        #50;
            $display("50 : %d", sort.sorted[i]);
        nrst = 0;
        #50
            $display("100 : %d", sort.sorted[i]);
        nrst = 1;
        #50
            $display("150: %d", sort.sorted[i]);
    end
endmodule
  • \$\begingroup\$ Task are normally reserved for testbenches and not synthesisable code. should it not return a value rather than use inouts? maybe a function is what you were wanting, except functions have to execute in zero time. \$\endgroup\$ Mar 16, 2016 at 14:16
  • \$\begingroup\$ When I declare a function with return type of byte [0:3](for sorted list), Modelsim give error 'can't assign unpacked...'. I didn't know how to return a list of bytes from a function, so I preferred using task. I think tasks are synthesisable as well as functions. \$\endgroup\$ Mar 16, 2016 at 14:39
The problem is there is a mismatch in the index declaration for sorted[0:3] versus list[3:0], so (list[j] < list[j+1]) gives you the reverse evaluation. I strongly recommend using common typedef's (in a package) to eliminate problems like this.
typedef byte list_t[4];
list_t sorted;
task sort_task( inout list_t list);
BTW, using a typedef gives you the syntax needed to declare a function with unpacked return type because any simple name is allowed for a return type, no matter how complex the typedef is.
Also, I agree with you that a task is synthesizable, as long as the code inside the task is meets your tools synthesis modelling style. But I would prefer that people use a void function instead of a task when their task has no time consuming statements. A function is a guarantee that it will not consume time.
  • \$\begingroup\$ This is being assigned as synchronous logic, therefore non-blocking assignments (<=) is recommended. Blocking assignments should be used inside method to keep it portable and self-contained. I'd suggest the method header be function list_t sort_func( input list_t list); which returns the sorted list, and then you can assign the array as sorted <= sort_func(shorted);. \$\endgroup\$
    – Greg
    Mar 16, 2016 at 16:47
  • \$\begingroup\$ Thank you for your professional guidance. I was involved in this question that how can return a list from a function. Using typedef solved it. But I don’t understand why function is better the task. I think in compile time, inner codes of the both blocks will move to the place that they called. \$\endgroup\$ Mar 16, 2016 at 17:31
  • \$\begingroup\$ You will appreciate the guideline better when you start having nested calls to tasks and functions - especially when you start writing testbenches that have nested calls. Calling a function documents your intent that the call will not block, as well as any other nested call. The problem with using nested task calls is when a task deep inside your call stack has a modification that blocks - it will be very difficult to debug. Verilog did not have void functions - they always had to be used in an expression. That's why you see lots of non-time-consuming tasks. \$\endgroup\$
    – dave_59
    Mar 16, 2016 at 20:52
