I found this while taking apart a PSU, the closest label was B1. It appears to be a transformer-like component with two leads, and the coils on the vertical part around the core seem to be connected opposite the leads. Googling the label got me nowhere.
  • \$\begingroup\$ Interesting. I got some leads on the inscription, but they all seem to point to the frame of the unit which is apparently called U3216. For example this \$\endgroup\$
    – AndrejaKo
    Commented Nov 16, 2011 at 12:26
    \$\begingroup\$ Looks to me like it's just an inductor - kind of like a toroidal one with a closed loop for the induction core, just not in the shape of a toroid. \$\endgroup\$
    – Majenko
    Commented Nov 16, 2011 at 12:31
  • \$\begingroup\$ Dumping a 3000 x 2250 picture on us is ridiculous. It should be resized to 800 max. It wouldn't hurt to hold the camera still and focus more carefully either next time. \$\endgroup\$ Commented Nov 16, 2011 at 13:41
  • \$\begingroup\$ @Olin Lathrop: Welcome here for a possible solution: meta.stackexchange.com/questions/101439/… No need even for reupload - just change the link. m infix yields an even smaller image. \$\endgroup\$
    – sharptooth
    Commented Nov 16, 2011 at 14:43
    \$\begingroup\$ It would also help if you put a ruler next to it for scale. \$\endgroup\$
    – starblue
    Commented Nov 17, 2011 at 8:05
Just an inductor, it's used in some large switched mode psus to do powerfactor correction.
  • \$\begingroup\$ Yup, that's what I was going to say too. \$\endgroup\$ Commented Nov 16, 2011 at 13:40
