I'm trying to write a program using BASIC to turn a servo 180 degrees back and forth, and to use a potentiometer to control the speed at which the servo turns. I have a code, but when I run it, the servo freaks out and starts twitching in one spot, and I don't know why it's doing that or what's causing it. Can someone explain to me why it's doing that, what's causing it, or a way to fix it?
' What's a Microcontroller - ControlServoWithPotUsingDirectives.bs2
' Read potentiometer in RC-time circuit using RCTIME command.
' Apply scale factor and offset, then send value to servo.
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
rcPin PIN 5                                       ' I/O Pin Definitions
servoPin PIN 14
scaleFactor CON 15                               ' Constant Declarations
offset CON 1
delay CON 10
time VAR Word                                     ' Variable Declaration
PAUSE 1000                                        ' Initialization
DO
                                                  ' Main Routine
 HIGH rcPin                                       ' RC decay measurement
 PAUSE 100
 RCTIME rcPin, 1, time
 'time = time * scaleFactor                       ' Scale scaleFactor.
 'time = time + offset                             ' Offset by offset.
 'PULSOUT servoPin, time                           ' Send pulse to servo.
 'DEBUG HOME, DEC5 time                            ' Display adjusted time value.
 FOR counter = 300 TO 1100 STEP time
   PULSOUT servoPin, counter
   PAUSE 7
   DEBUG DEC5 counter, CR
   DEBUG DEC5 time, CR
 NEXT
 PAUSE 10
 FOR counter = 1100 TO 300 STEP time
   PAUSE 7
   DEBUG DEC5 time, CR
 NEXT
LOOP
  • \$\begingroup\$ Do you have an oscilloscope? \$\endgroup\$ Mar 18, 2016 at 13:02
  • \$\begingroup\$ I'm not using one for this program. I didn't see a need to use it. Do you think it would help? \$\endgroup\$
    – smith8m3
    Mar 18, 2016 at 13:08
    \$\begingroup\$ Oh, yes, definitely. Otherwise you're working blind. \$\endgroup\$ Mar 18, 2016 at 13:11
  • \$\begingroup\$ Are you giving the variable "time" an initial value? \$\endgroup\$
    – Nedd
    Mar 18, 2016 at 13:55
  • \$\begingroup\$ If it is not a programming issue, it may be that the potentiometer has a bad spot in its travel. A voltmeter may help to watch for erratic voltage swings on the wiper pin while you adjust it. As Spehro suggest using a scope at that point would be best. \$\endgroup\$
    – Nedd
    Mar 18, 2016 at 14:04
"Servo freaks out and starts twitching in one spot."
Check your connections to the servo, this sounds like an issue I had in my starting grad years: unshared GND. If you are using an external source to power the servo, the external source GND should be connected to the GND of the microcontroller. Otherwise, your servo control signal will not be referenced appropriately and will lead to "undefined behavior" in the form of twitching.
