-3
I want to send a video stream to a microcontroller via wifi. what microcontroller choose for this task? -Must take into account that the video will be transmitted through a phone -The video will be in different format and larger format will be HD (1920 * 1080) -The video is intended to be displayed on a TV screen -The video will be played at the same time it is to be sent to crotch... I work on a project to read streaming a video that is in the phone by a plasma tv... I had my start and I still looking for landmarks
    \$\begingroup\$ 1920x1080x24bit @ 60FPS has a raw bit rate of 3Gbps. How on earth do you expect a tiny microcontroller to receive that much data and send it out to a PC? This question has been asked many times before with the same answer, no you can't. \$\endgroup\$ Commented Mar 19, 2016 at 16:29
    \$\begingroup\$ Possible duplicate of Transmitting a video stream through a microcontroller \$\endgroup\$ Commented Mar 19, 2016 at 16:30
  • \$\begingroup\$ Chances are you want at least a small system-on-module or embedded board with megabytes of SDRAM, either to buffer and pass on a compressed stream, or else to decompress and render it and drive an HDMI, RGB, or whatever interface. Look at the parts usually used in set-top-box applications, or those found in android tablets with video out. \$\endgroup\$ Commented Mar 19, 2016 at 16:30
  • \$\begingroup\$ Also duplicate of Transmitting a video stream through a microcontroller's wifi \$\endgroup\$ Commented Mar 19, 2016 at 16:31
    \$\begingroup\$ Questions seeking recommendations for specific products or places to purchase them are off-topic in this forum and will be closed. Reference: Help->Tour->Don't ask about...Shopping or buying recommendations. \$\endgroup\$
    – tcrosley
    Commented Mar 19, 2016 at 20:29
Microcontrollers, are designed for simple tasks, they can not do any thing any where near video, what you need is a microprocessor, that is capable of processing video.
  • \$\begingroup\$ What microprocessor for example? \$\endgroup\$
    – wahab
    Commented Mar 19, 2016 at 16:13
  • \$\begingroup\$ the microcontroller does not generate or process the video but will just pass it to the tv \$\endgroup\$
    – wahab
    Commented Mar 19, 2016 at 16:16
  • \$\begingroup\$ TV's don't generally accept video in microcontroller-friendly formats \$\endgroup\$ Commented Mar 19, 2016 at 16:29
    \$\begingroup\$ Sorry, I went to walk my dog. Currently looking for one now. Will update when I find one. \$\endgroup\$
    – Alex
    Commented Mar 19, 2016 at 17:03
  • \$\begingroup\$ the raspberry pi 2 go? \$\endgroup\$
    – wahab
    Commented Mar 19, 2016 at 20:24
