Apologies if this is a bit simple, but I'm new to this!
How do I set the speed for a 4060B chip? I want it to trigger every 5 minutes (fairly accurately).
I've looked at the instructions here: http://www.reuk.co.uk/Timer-Circuits-With-4060B.htm and it looks like I need to trigger on pin 4. However, I don't get how I set the resistors and capacitor.
According to the datasheet the formula for the R/C oscillator is:
\$ {\dfrac{1}{2.3 \cdot R1\cdot Cx}} \$
So for R1 = 10k\$ \Omega \$ and Cx = 10\$\mu F \$
\$ {\dfrac {1}{2.3 \cdot 10k \Omega\cdot 10 \mu F}} = 4.34Hz \$
You can use any of the Q4 to Q14 pins for output, they have different division ratios of the oscillator speed.
Where Osc = the oscillator frequency the frequency of each Q pin is Q4 = Osc / 16, Q5 = Osc / 32, Q6 = Osc / 64 and so on up to Q14 = Osc / 16384.
So with the above example Q4 will toggle every \$ {\dfrac{1}{4.34Hz}} \cdot 16 = 3.68\$ seconds
For five minutes you simply need to choose a compatible frequency and divider ratio. 5 * 60 = 300 seconds. If we choose the divider as Q6 then 300/64 = 4.68 seconds needed for the oscillator.
A quick shuffle of some figures gives one possible way as R1 = 204k\$\Omega\$ and Cx as 10\$\mu\$F. This would give:
\$ 64 \cdot \left( \dfrac{1} {{\dfrac{1}{2.3 \cdot 204k\Omega \cdot 10\mu F} }}\right) = 64 \cdot 2.3 \cdot 204k\Omega \cdot 10\mu F = 300.288\$ seconds.
Pretty close. I would probably use a smaller more precise capacitor and a larger resistor for more accurate timing. For best accuracy use the crystal option.
  • \$\begingroup\$ With such a long divider chain available you can use a faster oscillator and a bigger divide ratio. If your oscillator operates at say 10 to 100 hz the components are usually much more manageable that if you need somewhere around 1 HZ BUT do what works best for you in practice. | Do not use an elecrolytic for timing or a cap that is badly temoerature affected. eg most ceramics are poor. Use a quality resistor. (Most are these days. Most.) \$\endgroup\$
    – Russell McMahon
    Nov 17, 2011 at 18:15
You said fairly accurately. So I wouldn't use an RC oscillator but a crystsal oscillator. The 4060 can also be operated as crytstal oscillator.
A 32.768kHz (clock) crystal would yield a 2 Hz signal (after all 14 stages of the 4060). So you need another divider/counter, e.g. a 4040 to count 5 * 60 * 2 = 600 pulses at 2 Hz.
You can use half a 74HC21 (4 input AND gate) or a simple wired-AND gate to detect the terminal count (600 = 512 + 64 + 16 + 8 = 2^9 + 2^6 + 2^4 + 2^3).
Or probably cheaper and more flexible with just one IC: use a small crystal clocked microcontroller.
