-2
I'd like to use this heater element for a project I'm working on. It looks like a good product but there is unfortunately not much documentation available, but I think it's basically a simple resistive load that can operate from 230V AC. So I started to look around to see how I could control the temperature of this heater and found an interesting circuit in Power Semiconductor Applications (chapter 6.2.2) by Philips:
This circuit produces the following output:
This looks like it could do the job for me. According to the description, it is controlled by the resistance of the potentiometer R2.
Now my question is, instead of a manual potentiometer, how can I modify this circuit to control it electrically, with an MCU (microcontroller)?
Alternatively, what other circuit could I use that can be controlled using an MCU that would achieve the same ends?
Note, I'd also prefer to keep this galvanically isolated from the MCU. I believe this could be achieved using an optocoupler, but I'm not a power expert, so I'm not sure which kind I need here.
Thank you in advance for your help!
  • \$\begingroup\$ That kind of circuit is remarkably ill-suited to being controlled by a microcontroller. \$\endgroup\$ – Spehro Pefhany Mar 20 '16 at 21:07
  • \$\begingroup\$ @SpehroPefhany I know, that's why I'm asking how to modify it. I'm open to suggestions about alternatives, too. :) \$\endgroup\$ – Venemo Mar 20 '16 at 21:08
Consider an SSR controlled with the MCU via PWM and with a short (~2 second) proportional cycle. You can use a temperature sensor and feedback control or open loop, depending on requirements.
The SSR provides the isolation, You'll need a large-ish heat sink and/or fan for any solid-state switching.
You should also consider what happens when (not if) the SSR or micro gets stuck on and make sure there is adequate safety provisions (maybe a thermal cutoff or other protections) to prevent injury or property damage.
What you've shown is a phase control- it will cause a lot of electrical noise and is probably unnecessary for this application.
  • \$\begingroup\$ Good point about phase control. Would triggering only at zero-crossings be less noisy? Does the SSR do that automatically? Are there any other advantages of the SSR over a thyristor? \$\endgroup\$ – Pigrew Mar 20 '16 at 21:18
  • \$\begingroup\$ The problem with an SSR is that it's wildly expensive (and big) compared to anything that you can build with a triac. \$\endgroup\$ – Venemo Mar 20 '16 at 21:19
  • \$\begingroup\$ By the way, I added a picture of what the output is, this doesn't look like phase control for me. \$\endgroup\$ – Venemo Mar 20 '16 at 21:22
  • \$\begingroup\$ @Pigrew Yes, the zero crossing type would be less noisy- but there might be more beat problems as the cycle is shortened. An AC SSR is just a thyristor with an optocoupler, snubber, and drive circuit for the LED. The OP can build one himself. \$\endgroup\$ – Spehro Pefhany Mar 20 '16 at 21:23
  • \$\begingroup\$ @Venemo Are you planning on using it with a vacuum cleaner motor load? Your link is to an almost purely resistive heater. \$\endgroup\$ – Spehro Pefhany Mar 20 '16 at 21:33
