After fixing my Up Counter, I'm having troubles writing structural verilog code for an Asynchronous 4-bit Down Counter using D Flip Flops.
Here's the D Flip Flop code (which was tested and works):
module DFlipFlop
  input wire    reset_n,
  input wire    clk,
  input wire    d,
  output wire   q,
  output wire   q_n
  wire w1, w2, w3, w4, w5, w6;
  //master
  nand na1(w1, d, ~clk);
  nand na2(w2, ~clk, ~d);
  nand na3(w3, w1, w4);
  nand na4(w4, w3, w2);
  //slave
  nand na5(w5, w3, clk);
  nand na6(w6, clk, ~w3);
  nand na7(q, reset_n, w5, q_n);
  nand na8(q_n, q, w6);
endmodule
And my Down Counter Code using this image: enter image description here
module Count4Down
  input wire      reset_n,
  input wire      clk,
  output [3:0]    q
  wire qn0, qn1, qn2, qn3;
  DFlipFlop ff0(reset_n, clk, qn0, q[0], qn0);
  DFlipFlop ff1(reset_n, q[0], qn1, q[1], qn1);
  DFlipFlop ff2(reset_n, q[1], qn2, q[2], qn2);
  DFlipFlop ff3(reset_n, q[2], qn3, q[3], qn3);
endmodule
And the Testbench:
module testbench;
  reg clk, reset_n;
  wire [3:0] q;
  Count4Down u1(.clk(clk), .reset_n(reset_n), .q(q));
  initial begin
    forever begin
        clk <= 0;
        #5
        clk <= 1;
        #5
        clk <= 0;
    end
end
  initial begin
    $dumpfile( "dump.vcd" );
    $dumpvars( 1, testbench );
    reset_n = 0;
    #12
    reset_n = 1;
    #170
    reset_n = 0;
    #12
    reset_n = 1;
    #200  $finish;
  end
endmodule
When I run it, it only displays a series of x's. I tried the testbench with some working code of a down counter I found online and it displayed things correctly, so I'm led to believe the problem lies within my Down Counter Code. So what am I doing wrong? Thanks in advance!
  • \$\begingroup\$ The easiest way to make a down-counter is to take an up-counter and monitor the Q* outputs. \$\endgroup\$ Commented Mar 22, 2016 at 16:14
What I found is, your code is correct but at posedge count down is happen but at same tick 0xF is (reset value), also driven by this code, check that monitor output, see attached log file
module DFlipFlop
  input wire    reset_n,
  input wire    clk,
  input wire    d,
  output wire   q,
  output wire   q_n
 //master
 nand na3(w3, reset_n, w1, w4);
 //slave
endmodule
module Count4Down
  input wire      reset_n,
  input wire      clk,
  output [3:0]    q
endmodule
module testbench;
  reg clk, reset_n;
  wire [3:0] q;
  initial
  begin
    $display ("Clk\t reset_n\t count\t ");
    $monitor ("%b\t %b\t\t %b",clk,reset_n,q);
    clk = 0;
    reset_n = 0;
    #10 reset_n = 1;
    #100 reset_n = 0;
    #20 $finish;
  end
  always clk = #1 ~clk;
endmodule
I think is q is have complicated driving logic, check it.
QuestaSim-64 qverilog 10.4 Compiler 2014.12 Dec  2 2014
Start time: 15:59:44 on Mar 22,2016
qverilog count.v
-- Compiling module DFlipFlop
-- Compiling module Count4Down
-- Compiling module testbench
Top level modules:
    testbench
Reading pref.tcl
 10.4
 vsim -lib work testbench -c -do "run -all; quit -f" -appendlog -l qverilog.log -vopt
 ** Note: (vsim-8009) Loading existing optimized design _opt
 //  Questa Sim-64
 //  Version 10.4 linux_x86_64 Dec  2 2014
 //  Copyright 1991-2014 Mentor Graphics Corporation
 //  All Rights Reserved.
 //  THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
 //  WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS
 //  LICENSORS AND IS SUBJECT TO LICENSE TERMS.
 //  THIS DOCUMENT CONTAINS TRADE SECRETS AND COMMERCIAL OR FINANCIAL
 //  INFORMATION THAT ARE PRIVILEGED, CONFIDENTIAL, AND EXEMPT FROM
 //  DISCLOSURE UNDER THE FREEDOM OF INFORMATION ACT, 5 U.S.C. SECTION 552.
 //  FURTHERMORE, THIS INFORMATION IS PROHIBITED FROM DISCLOSURE UNDER
 //  THE TRADE SECRETS ACT, 18 U.S.C. SECTION 1905.
 Loading work.testbench(fast)
 run -all
 Clk     reset_n     count
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   1       1111
 1   1       1110
 0   1       1110
 1   1       1101
 0   1       1101
 1   1       1100
 0   1       1100
 1   1       1011
 0   1       1011
 1   1       1010
 0   1       1010
 1   1       1001
 0   1       1001
 1   1       1000
 0   1       1000
 1   1       0111
 0   1       0111
 1   1       0110
 0   1       0110
 1   1       0101
 0   1       0101
 1   1       0100
 0   1       0100
 1   1       0011
 0   1       0011
 1   1       0010
 0   1       0010
 1   1       0001
 0   1       0001
 1   1       0000
 0   1       0000
 1   1       1111
 0   1       1111
 1   1       1110
 0   1       1110
 1   1       1101
 0   1       1101
 1   1       1100
 0   1       1100
 1   1       1011
 0   1       1011
 1   1       1010
 0   1       1010
 1   1       1001
 0   1       1001
 1   1       1000
 0   1       1000
 1   1       0111
 0   1       0111
 1   1       0110
 0   1       0110
 1   1       0101
 0   1       0101
 1   1       0100
 0   1       0100
 1   1       0011
 0   1       0011
 1   1       0010
 0   1       0010
 1   1       0001
 0   1       0001
 1   1       0000
 0   1       0000
 1   1       1111
 0   1       1111
 1   1       1110
 0   1       1110
 1   1       1101
 0   1       1101
 1   1       1100
 0   1       1100
 1   1       1011
 0   1       1011
 1   1       1010
 0   1       1010
 1   1       1001
 0   1       1001
 1   1       1000
 0   1       1000
 1   1       0111
 0   1       0111
 1   1       0110
 0   1       0110
 1   1       0101
 0   1       0101
 1   1       0100
 0   1       0100
 1   1       0011
 0   1       0011
 1   1       0010
 0   1       0010
 1   1       0001
 0   1       0001
 1   1       0000
 0   1       0000
 1   1       1111
 0   1       1111
 1   1       1110
 0   1       1110
 1   1       1101
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1112
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 0   0       1111
 1   0       1111
 ** Note: $finish    : count.v(59)
    Time: 130 ns  Iteration: 0  Instance: /testbench
 End time: 15:59:45 on Mar 22,2016, Elapsed time: 0:00:01
 Errors: 0, Warnings: 0
