I have made a quick search but couldn't find anything specific around.
I need to design a rudimentary circuit for a photodiode in conductive mode. I am interested in high speed rather than sensitivity, a wavelength around 550nm.
I have a notional idea of a battery connected across the legs as a voltage bias, but how do calculate what resistor to use to avoid overloading the diode...
Sorry for being vague, I'm struggling to find out where to begin!
(nb. I have a background in physics so have a basic knowledge of electronics.)
  • \$\begingroup\$ What speed do you need? \$\endgroup\$ Nov 18, 2011 at 12:49
  • \$\begingroup\$ ideally ns response times, ie GHz frequency discrimination. \$\endgroup\$
    – Nic
    Nov 18, 2011 at 17:14
I'll edit this answer severely as a general comment:
Photodiodes may be operated either forward or reverse biased.
  • Forward biased gives most output.
  • Reverse biased gives most speed. and is noisier.
    In this mode Vsupply needs to be < Vreversebreakdown - hopefully in the data sheet.
Reverse biased mode is most usually used.
The Sharp BS120 is optimised for 560 nM operation. It specifies Vreverse_abs_max as 10 volts and has curves all the way up (or down) to -10V.
Wikipedia says
In "forward biased" mode the diode is usually operated with NO added bias and is used as a voltage source.
For a silicon diode with Vforwards = Vf = 0.6V . Say you want 5 mA current and are using a 5V supply then
I = V / R = = (Vsupply - Vdiode) / R = (5-0.6) / 0.005 = 880 ohms Say 1000 Ohms (which gives a notional 4.4 mA)
For 1 mA you'd use (5-0.6)/0.001 = 4400 Ohms
  • \$\begingroup\$ Yes, but a photodiode should be reverse biassed as per Konsalik's answer! \$\endgroup\$
    – MikeJ-UK
    Nov 18, 2011 at 13:08
  • \$\begingroup\$ @MikeJ-UK Ah - terminology brainfade - I'm well aware of the normal reverse biased mode - "conductive mode implied to me conductive whereas its just the opposite. A photodiode may be operated in either polarity - with different results in each case. Either may be preferred depening on requirement. What he wanted was in fact reverse biased mode, as you noted :-) \$\endgroup\$
    – Russell McMahon
    Nov 18, 2011 at 13:31
Russel explains the calculation of the resistor in his post above. Here is a simple circuit:
Note that the diode is reverse biased for "photoconductive" mode as Mike explained in his comment on your question.
  • \$\begingroup\$ As above :-). I'm well aware of the normal reverse biased mode - "conductive mode implied to me conductive whereas its just the opposite. What he wanted was in fact reverse biased mode, as you noted :-) \$\endgroup\$
    – Russell McMahon
    Nov 18, 2011 at 13:32
