In a monostable configuration of the 555:
http://circuitdigest.com/electronic-circuits/555-timer-monostable-circuit-diagram
I have connected pin2 to the ground all the time. My goal is that once the circuit is powered on it starts the counting down right away then turns off after x seconds but this is not what's happening.
The output load will be turned on this way all the time.
How to do it properly then?
Thanks
