I would like to measure the amount of power that is delivered by the Sun during the day. I have a nice housing (a waterproof glass hemisphere with aluminium base) from an outdoor IP camera and have been thinking about putting small solar cell in it.
I know I can calculate DC power in Watts as P = UI and knowing the area of the panel, calculate the amount of immediate power that is being delivered to a square meter. (And I would need to know the panel's efficiency.)
Sure enough there are devices to measure power yield of a solar panel, could anyone explain how these operate so that I can build myself one?
Thanks!
A maximum power point tracking (MPPT) chip will keep the solar cell working at it's peak power output. These chips sometimes have an output that will report the instantaneous power.
You can more simply measure the power using two multimeter. One multimeter measures the potential across the cell, and the other measures the current. Like this:
The instantaneous power is simply the product of voltage and current. Do note that the power delivered depends very much on the load.
Power delivered by the solar cell (the blue line on the graph) peaks at a point between the maximum voltage and maximum current delivery. This is important to choose the right load in order to maximize the power delivered by the solar cell. Alternatively, you can use a MPPT, which automatically tracks the maximum power point.
