I want to do RS-232 communication with a PC terminal using interrupt on the receiving for the STM32F11RE. I've done polling using
HAL_UART_Receive(&huart2,&data1,sizeof(data1),HAL_MAX_DELAY);
in a while loop, echoing back upon completion lie this:
HAL_UART_Transmit(&huart2,"OK",sizeof("OK"),HAL_MAX_DELAY);
Now I want to do the same but without polling, but I don't know how to proceed. The manual says "Enable the NVIC USART IRQ handle.", but there is no reference to NVIC in STM324fxx_hal_uart.c There is a function
void HAL_UART_IRQHandler(UART_HandleTypeDef *huart);
Since it has an input argument, I guess this is not called by an interrupt vector somewhere. It must be the case that I will have to call it from main. Should I somehow create a highpriority task and call the IRQ-handler? Currently I have disbaled FreeRTOS. There is a global interrupt flag that I checked in the CubMx.
I've add this now
void USART2_IRQHandler(void)
HAL_UART_IRQHandler(&huart2);
uint8_t data1;
 HAL_UART_Receive_IT(&huart2,&data1,sizeof(data1));
      if(data1 > 0)
          HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin,GPIO_PIN_SET);
          HAL_UART_Transmit_IT(&huart2,"OK",sizeof("OK"));
It works with this in main:
void MX_USART2_UART_Init(void)
 huart2.Instance = USART2;
 huart2.Init.BaudRate = 115200;
 huart2.Init.WordLength = UART_WORDLENGTH_8B;
 huart2.Init.StopBits = UART_STOPBITS_1;
 huart2.Init.Parity = UART_PARITY_NONE;
 huart2.Init.Mode = UART_MODE_TX_RX;
 huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
 huart2.Init.OverSampling = UART_OVERSAMPLING_16;
 HAL_UART_Init(&huart2);
 HAL_NVIC_SetPriority(USART2_IRQn,14,0);
__HAL_UART_ENABLE_IT(&huart2,UART_IT_RXNE);
The interrupt handler will be located in stm32f4xx_it.c
You will find UART interrupt handler and callback function, you can add your code instead.
for example if you would like to store the recieved data in a special array or transimt the characters somewhere , just make sure to clear the flags if you are not using the callback function.
  • \$\begingroup\$ I located the function, when I ran it I don't enter the irq-routine when sending a character from PuTTY. I haven't touched anything in main. \$\endgroup\$ Commented Mar 26, 2016 at 14:52
  • \$\begingroup\$ When I send a character in the terminal, I get "OK" different amount of times. Why is that happening? I tried to disable interrupt when entering, and, enable it again when leaving the interrupt handler, the result was that it was alternating between printing non-stop and pausing ?!?! \$\endgroup\$ Commented Mar 26, 2016 at 17:18
  • \$\begingroup\$ HAL_UART_Receive_IT(&huart2,&data1,sizeof(data1)); have u read in HAL manual what does this function do exactly, becuase i takes the size of the buffer . instead of this condition if(data1 > 0) and sending "OK" let the the function at each interrupt send you the character it recieves , in this way it is easier to debug \$\endgroup\$
    – ElectronS
    Commented Mar 28, 2016 at 7:48
