Fellas,
When we use the term SCHEDULING in wired/wireless communication, does it relate to a physical layer functionality or a Data (MAC) layer functionality or to both?
MAC Functions: Physical addressing (MAC addressing) LAN switching (packet switching), including MAC filtering, Spanning Tree Protocol (STP) and Shortest Path Bridging (SPB) Data packet queuing or scheduling Store-and-forward switching or cut-through switching Quality of Service (QoS) control Virtual LANs (VLAN)
PHY functions: Bit-by-bit or symbol-by-symbol delivery Providing a standardized interface to physical transmission media,Modulation Line coding Bit synchronization in synchronous serial communication Start-stop signalling and flow control in asynchronous serial communication Circuit switching Multiplexing,Carrier sense and collision detection utilized by some level 2 multiple access protocols Equalization filtering, training sequences, pulse shaping and other signal processing of physical signals Forward error correction[5] for example bitwise convolutional coding Bit-interleaving and other channel coding The physical layer is also concerned with:
Bit rate Point-to-point, multipoint or point-to-multipoint line configuration Physical network topology, for example bus, ring, mesh or star network Serial or parallel communication Simplex, half duplex or full duplex transmission mode Autonegotiation,
see wiki for each layer.
The scheduling of when to send data is part of framing which occurs in the data layer. Of course the parameters of the physical layer come into play in those decisions (can we send and receive simultaneously? what throughput is possible?) but the data layer makes the decision.
