About my previous question: CMOS tri-state buffer internal structure
I have just one more question: is the value that "activates" the transistor related to the value of the Output? Because if I choose the input "high" and the control "high" I will activate the top transistor in "low" but the output value should b e "high". So it's not related, right?
Thanks!
  • \$\begingroup\$ Can you make this a self-contained question, including the circuit diagram? \$\endgroup\$ – Wouter van Ooijen Mar 25 '16 at 15:35
    \$\begingroup\$ You need to study how PMOS transistors work. Common source configuration is inverting for either PMOS or NMOS. \$\endgroup\$ – The Photon Mar 25 '16 at 15:35
  • \$\begingroup\$ is the value that "activates" the transistor related to the value of the Output? NO, it is not, the transistors are either in a conductive state or not, depending on the gate-source voltage. Given enough gate-source voltage a conductive channel is formed between drain and source. This channel is formed regardless of the drain (output) voltage. \$\endgroup\$ – Bimpelrekkie Mar 25 '16 at 15:48
  • \$\begingroup\$ Thinking of transistors as "activated" is a shortcut that will mislead you until you learn how they actually work. There is no royal road to learning, as the saying goes. \$\endgroup\$ – pjc50 Mar 25 '16 at 16:22
Very roughly, the action of a MOSFET is controlled by the voltage between the gate and the source terminal. More detailed schematic symbols for MOSFETs make these two terminals look different:
In your circuit, the source is the one connected to the positive power supply node. The action is controlled by how far below the source is the gate voltage.
