I own a Revo Blik radio that has developed a flaw: the display doesn't completely light up anymore when activating the device. When you're close by you can make out what it says, but not from a regular distance. It sometimes flickers to full brightness a few times before failing.
I opened it up and there is a white led mounted on the side of the display, I suppose serving as its backlight. Since opening it up, it flickers constantly when the device is in operation.
I'm not really sure how to proceed from here to diagnose the problem. As a physicist and programmer, I think I have the necessary background to understand and fix the problem (if possible), but I have little experience with working with the hardware itself and specifically don't have any substantiated hypotheses as to what could cause this behavior, other than a hunch may is simply be a faulty contact along the power path to the LED, like in a buzzing lightswitch. Is that possible or doesn't that happens with these low voltages?
Does anyone have an idea what the problem may be and how I may proceed from here to fix this problem?
Edit: As requested, I added some photos. They can be seen here (if you hover over the photos, there are some descriptions of what you see, but they are not all complete; if you click on a photo, they become somewhat larger and display the full comment). The led itself is hidden under some adhesive tape that I'm not sure I should remove: I think it fixes something underneath in place, although the entire display seems to be stuck to the board pretty solidly.
@AndrejaKo: immediately after booting, the led emits at full strength for ~ one second. After that, the flickering starts. I don't have the means to identify a specific (average) frequency, but it's easily visible by the eye. I would say it's between 5 and 20 Hz: the intervals are irregular. Certainly not so slow I could count the flickers and certainly not so fast that I have a hard time seeing it is flickering.
@Oli Glaser: I've tried tapping the board and touching/pressing various components, but that didn't change anything. I'll try to get my hands on on a hairdryer and something to cool the device. I failed to identify a specific IC as the one that drives the led. I need to disassemble the device further to follow the lines.
@Majenko and JustJeff: if it's a dry joint, applying some pressure to the right component should result in the flickering stopping, right? That would be just like the buzzing lightswitch?
