8
I have had great success in the past using the reflow soldering method, using a syringe and needle to apply the paste to the board. However, I found myself repeatedly making the same boards so I decided to purchase some stencils.
I purchased a framed metal stencil for one PCB design and a 4 mil mylar stencil for the other.
They have worked well, until one day I forgot to clean the stencil after use. Now the solder has hardened and it is not wiping off.
Is there something I can use to dissolve the solder so that I can wipe it clean? Also, do I use different products for my metal stencil and mylar stencil?
NB. I am using no clean solder paste by AIM: http://www.aimsolder.com/products/No%20Clean
    \$\begingroup\$ Did you try the jellybean solution: isopropylalcohol? \$\endgroup\$ Mar 26, 2016 at 9:18
  • \$\begingroup\$ IPA should work, yes. \$\endgroup\$
    – Asmyldof
    Mar 26, 2016 at 9:28
  • \$\begingroup\$ Will IPA dissolve the mylar stencil at all? Also I heard that IPA is good for rosin based solder paste but not so good at the no clean varieties. Is this true? \$\endgroup\$
    – sa_leinad
    Mar 26, 2016 at 9:42
  • \$\begingroup\$ isopropyl alcohol, methylated spirits, or just scrub at it with a wire wool. \$\endgroup\$
    – Alex
    Mar 26, 2016 at 11:26
  • \$\begingroup\$ same problem here... did you find a solution? \$\endgroup\$ Jul 6, 2017 at 15:31
I have found that the best solution (pardon the pun) is to use Isopropyl Alcohol (IPA). It removes the solder with the least amount of effort. I have had no problems when I have used Isopropyl Alcohol with the no-clean varieties of solder paste.
Methylated Spirits works as well but not as well as Isopropyl Alcohol.
Isopropyl Alcohol will be fine on mylar stencils.
I have found that it is best to use an old rag when cleaning off the solder paste. Tissues etc. catch on the holes and rip, leaving bits of tissue behind in the holes. Steel/wire wool also catches in the holes and pulls and can damage the stencil.
  • \$\begingroup\$ Mylar won't "melt" when exposed to IPA. \$\endgroup\$
    – JRE
    Jul 6, 2017 at 16:19
