Are there any significant differences with respect to heat generation of a bridge rectified circuit with smoothed DC by use of a capacitor vs one that just uses the raw absolute value of the sine wave? I'm having a bit of trouble with my bridge overheating and I was wondering if smoothing the output would help. (Aside for putting a heat sink on it, which I'm in the process of doing) The bridge runs at 30A typically (rated for 100A) and starts getting hot kind of fast, but I only really use it for less than a minute anyway since the system I use it for is very efficient.
Edit 0: The load is used for various electrochemical reactions done at low voltage (9V DC) and high current (30A DC). The reaction doesn't really care whether the DC is smoothed or not. The question refers to how much heat the bridge is building up, not that I'm running a heater. I'll admit, when I first saw the comment on someone thinking I was running a heater I had quite the laugh (As I suppose with how much heat the bridge builds up if not monitered or used for more than 4 minutes I probably would be!).
Edit 1: Yes (Before anyone tells me), I know that it's a small spot welder essentially, and the proper fuses are in place.
  • \$\begingroup\$ Why do you need to rectify at all if you're only driving a heater? \$\endgroup\$
    – brhans
    Mar 30, 2016 at 20:39
  • \$\begingroup\$ @brhans Who says anything about a heater? It's the bridge that's getting hot. \$\endgroup\$
    – pipe
    Mar 30, 2016 at 20:45
    \$\begingroup\$ The question seems to be misleading some folks- the heating in questions is the bridge, nothing is said as to what the load is, but I guess if it tolerates pulsating DC it can't be too fussy so I guessed a resistance. Anything more and the OP will have to enlighten us. \$\endgroup\$ Mar 30, 2016 at 20:46
    \$\begingroup\$ @SpehroPefhany Edits made to avoid more bridge rectifier-heater hijinks. \$\endgroup\$ Mar 30, 2016 at 21:38
    \$\begingroup\$ A 30A bridge will need a heatsink for sure. \$\endgroup\$
    – user16324
    Mar 30, 2016 at 21:41
7
Adding a large capacitor will increase the heating of the bridge, assuming a constant resistance load. The average and the RMS currents through the bridge will both increase, so more heat (but also more output power).
Because the capacitor charges in sharp pulses, the heating will actually be more than you might expect from the average output current increase. That is because the diode forward voltage increases with current, and a portion is actually resistive so some component of the heating is related to the current squared and not just the current (hence RMS current).
Adding a smoothing capacitor will increase the average voltage of the power supply as the capacitor will continue to supply current during the dips in the rectifier output. This will increase the current and power to your heater. Obviously this power has to come from the transformer so the rectifier will run even hotter.
You should calculate the power dissipated in your rectifier - current through it by voltage drop across a diode x 2. (2 diodes will be conducting at any time.) Then refer to the datasheet and perform a thermal calculation with the data you have.
Your heater probably doesn't require DC. Can you supply it with AC, bypassing the rectifier?
  • \$\begingroup\$ Is there something I'm missing here or why do you assume the load is a heater? The problem is the bridge getting hot. \$\endgroup\$
    – pipe
  • \$\begingroup\$ "... With Respect to Heating" in the title was in the back of my mind. I assumed that a full-wave unsmoothed output was driving a heater. I see bhrans understood the same as me. \$\endgroup\$
    – Transistor
    Mar 30, 2016 at 21:23
  • \$\begingroup\$ @transistor Sorry, design oversight. \$\endgroup\$ Mar 30, 2016 at 21:47
