I'm looking for a small fairly rugged normally open switch that closes when a "pin" is removed. It needs to take about 12V It needs to be passive and not require power. Is there such a component?
Basically, I want to be able to pull out a pin or a small plug to turn a device on.
I can think of a mechanical solution, a plastic pin that blocks the current flow, once removed the contacts would press together. But, for my application (a drone) I don't think I can build something rugged enough.
So is there a type of store-bought component that will do this?
  • \$\begingroup\$ sure. take a clothes pin, the old wooden type, glue some copper pads to the ends, for contacts. Then add wire to each contact. insert some insulator like a piece of hard plastic for the "Pin." There you have it. I hope this isn't for some kind of bomb. No, of course not in this day & age. \$\endgroup\$ – Tim Spriggs Mar 30 '16 at 22:24
  • \$\begingroup\$ Take a look here \$\endgroup\$ – EM Fields Mar 30 '16 at 22:31
  • \$\begingroup\$ Any pin-activated switch which is SPDT will do what you want. You use the common and the NC contacts. \$\endgroup\$ – WhatRoughBeast Mar 30 '16 at 22:41
    \$\begingroup\$ These things often go as remove before flight switch [or pin]. It's also possible to rig a switch like that out of a DC barrel jack. \$\endgroup\$ – Nick Alexeev Mar 30 '16 at 22:42
3.5mm Audio Jack with switch?
DC Barrel Jack (2.1mm / 2.5mm) with internal switch lip?
About any round connector meant for low power multi-media will have variants with a switch inside.
|improve this answer|||||
