I have an external consumer product what I try to automate by connecting my Arduino to its push buttons. This device uses internally 5V, I can get this voltage on the switch buttons as well.
push
My goal would be to automate this without relays to keep my circuit small and quiet.
I have tried 2 methods so far:
http://www.instructables.com/id/Small-Triac-Switch/
-Connecting the buttons to the triac
-Connecting the buttons to the MOC directly
The results were the same. For the first time the switch works (device turns on) but any other attempts are ignored. I would like to understand why and how to modify my circuit to work possibly with the components I have on hand (TIC206 or MOC3041).
I got the triac in high power switching in mind because I didnt know what the device uses internally until I disassembled it but I would say the MOC should be good enough for switching 5V.
If I use a relay or just sort the wires by hand that works 100%.
moc
You mention "TRIAC".
A TRIAC is a double thyristor and a thyristor is a switching transistor type device that you can switch ON by providing a current through it's gate but you can only switch it OFF if you interrupt the current that it is switching !
I think you are switching a DC signal (the 5 V you measure) so even if you turn the gate signal off (like you do) it will stay ON no matter what. TRIAC switches are for switching AC currents, not DC !
I suggest you get an optocoupler with a phototransistor, not one with a TRIAC / thyristor !
The opto-triacs are intended for switching alternating current and are a poor choice for this application. You need to use a transistor type opto-isolator.
The two most likely swithing arrangements of your "external consumer product" are shown in Figure 1 and 2.
Figures 1, 2 and 3.
A transistor type opto-isolator will work for either pull-up or pull-down circuit.
  • Connect the opto-transistor collector to the positive side of the button.
  • Connect the opto-transistor emitter to the negative side of the button.
  • Connect the opto-LED as shown to your Arduino.
  • \$\begingroup\$ Thanks for the diagram, can't I use the MOC3041? It is supposed to be an opto isolator.. \$\endgroup\$
    – munin24
    Mar 31 '16 at 10:56
  • \$\begingroup\$ Fairchild say, " MOC3041M 6-Pin DIP 400V Zero Crossing Triac Driver Output Optocoupler" and I imagine they should know. Yes, it's an opto-isolator but as three of us have told you this is the wrong type of opto-isolator. It's for switching AC. You are switching DC. \$\endgroup\$
    – Transistor
    Mar 31 '16 at 11:05
A Triac with Zero-Cross detection works by turning an AC signal on or off at the Zero Crossing point. A DC signal does not have a Zero-Cross point.
You can use a dc optocoupler (4N35 is commonly used), or if you don't care or need isolation, a simple transistor.
R1 is a simple pull-down to prevent a floating base from turning the transistor on.
  • \$\begingroup\$ Hello, please suggest some specific models I can buy from digikey/ebay then for optocoupler. Is there a stability issue with using regular npn transistors for switching? Is there a possibility the device can turn on due to some error? I would like to avoid that. With a relay there is no possibility for that, its either off or on. Thanks \$\endgroup\$
    – munin24
    Mar 31 '16 at 12:08
  • \$\begingroup\$ The 4N35 is a common one for something like this. And no, a regular NPN wouldn't have any stability issues, as long as you don't leave the base floating. A Pull-Down resistor of 10~47kΩ from base to ground would do that. An Opto-coupler is basically an led with light sensitive transistor in a box anyway. @munin24 \$\endgroup\$
    – Passerby
    Mar 31 '16 at 19:01
