Assume this schematic:
What I1 does and why isn't important, we just know it sources exactly 10μA.
The transistor Q1 is a type that, in this set-up happens to have an exact current gain factor of 100. Since this is a theoretical question, we can just assume that.
Now, that means that 1mA will flow into the collector right?
We also know that Ohm's Law teaches us that 1mA through 100 Ohm will only cause:
V = I * R = 0.001A * 100 Ohm = 0.1V
Add to that that the Battery BAT1 is 12V, we'll assume it ideal, so that we can say that across the resistor and transistor there is a total of 12V. If Q1 and R1 have 12V across them and R1 has only 0.1V across it, where does the rest go?
The only place it can: It falls across the Transistor.
Now, of course in the real world this voltage will slightly influence the current gain through some more complex formulas, but this is just to sketch the idea.
In the real world, there are quite a few other similar situations where such things happen.
And even if you use it as a hard-switch, the transistor will have a saturation voltage, the voltage that will always fall across the Emitter-Collector region, even if the path is fully turned on.
There are plenty transistors where this is only 0.1V in many use-cases, but if you'd put 100A through it, that's still 10W, which can be enough to kill any transistor. (Though types that can't handle that usually also don't handle 100A too well to begin with).
