When i've to generate PDF files with printout layers, i must always add the missing layer i need. For example i usually draw the board outline on keepout layer, so everytime i have to add the keepout layer on the printout set. Is there any way to build a custom template with all the printout layer and load it at once?
Yes it is possible.You can create your Output job file and use it as a template. Once you create Output job file as you wish, just add it in your project as Add existing to Project.
  • \$\begingroup\$ Thankyou. I've always thought must create new output job for each project. \$\endgroup\$ Apr 1, 2016 at 14:33
