Is there a way to construct a PLL cicruit which locks on to an input signal's phase but provides an output signal with different duty cycles?
  • \$\begingroup\$ Not sure why you want to use a PLL, simply triggering an adjustable monostable multivibrator from the input signal may do the job. \$\endgroup\$ – jippie Apr 2 '16 at 8:11
Trivially, PLL to 256x the signal frequency and feed that into a counter. Use the source clock to reset the counter.
| improve this answer | |
