I'm doing a PCB in which I'm using the Beagle Bone Black to interact with multiple I2C devices. I have attached a schematic. Out of the many I2C devices, I'm connecting some using TI's I2C switch PCA9548A (mainly for reducing the line capacitance).
I have the following questions
  1. Does my schematic make sense? Are there any glaring loopholes
  2. For the purpose of de-bugging (to see waveform quality, rise time etc), I bring out the main SDA, SCL lines and the switch lines SDA (1-4) and SCL(104) to 0.1 inch 2 Position headers (as shown in the Figure 2). Does bringing out I2C lines like this hurt the signal integrity and overall performance? Also am I doing it right?
  3. Since multiple devices use the same I2C lines, the section where the lines meet looks as shown in Figure 1. The white circles indicate the intersection of SDA/SCL lines from other devices. Does this make sense?
Thanks
Figure 1 Figure 1
Figure 2 Figure 2
  • \$\begingroup\$ Schematic images posted looks ok. What is the max speed u r operating. Those headers shouldn't disturb you... \$\endgroup\$ – user19579 Apr 4 '16 at 6:19
  • \$\begingroup\$ Just curious: how did you create the board when you don't have a real schematic? Or did you omit the schematic in your post? \$\endgroup\$ – uint128_t Apr 4 '16 at 15:54
  • \$\begingroup\$ I do have a schematic. Its distributed over 13 pages. For simplicity I enclosed the above schematic or should I say 'OmniGraffle block diagram' \$\endgroup\$ – am3 Apr 4 '16 at 15:55
The most glaring omission is the fact that this is an OmniGraffle block diagram, not a schematic. A reasonable schematic would show all connections and components.
No it doesn't hurt it. I do it with SPI all the time which can be much, much faster than I2C. I don't see how you could mess that part up!
You need to eliminate acute angles to reduce acid traps for board etching. Otherwise I2C is SO SLOW that you can treat it as a wire on a PCB. You can't get anything long enough on a circuit board for stub lengths or termination to matter. It gets a little more iffy when you start taking it between PCBs and over cables though.
The only thing I see here that looks weird is the low-speed resistors in the main branch (4.7k) and the high-speed resistors in the child branches (2k). Usually you use a lower resistance pull-up when you're running at 400kHz and 4.7k when you're running at 100kHz.
Note: This is not a 'normal*' mux.. rather it is a 'branch selector' that can have many or no branches connected. Your control byte, defined as enter image description here
is used to select the MOSFET switches individually
and you can turn on or off any branch arbitrarily.
*A normal mux would code to 001 -> 00000001, 010 -> 00000010, 011 -> 00000100...
|improve this answer|||||
  • \$\begingroup\$ Thanks Daniel. I think the 2k resistor is a good catch. The datasheet for PCA9548A does not give the resistors and I dont recall the reason I chose 2k over 4.7k. Entire system is at 100KHz. So I'll make the following changes 1) Change 2k --> 4.7k and 2) Make angles less acute (Although it will still work without this). Thanks! \$\endgroup\$ – am3 Apr 4 '16 at 16:01
  • \$\begingroup\$ That looks like Altium. You should set the Acute Angles rule. Typically I shoot for 90, but 70-80 works I guess. \$\endgroup\$ – Daniel Apr 4 '16 at 16:15
  • \$\begingroup\$ Also, do you realize that this mux can tie all of the busses together simultaneously? It's not a 'normal' mux, but more of a bus with on-off switches. \$\endgroup\$ – Daniel Apr 4 '16 at 16:16
  • \$\begingroup\$ Can you elaborate on your last comment? I didn't really understand the difference between this mux and the normal one. \$\endgroup\$ – am3 Apr 4 '16 at 16:17
  • \$\begingroup\$ @Agm I addressed it with an edit by adding some pictures from the datasheet. Where I said 'normal mux' I probably meant 'demux' ha \$\endgroup\$ – Daniel Apr 4 '16 at 16:27
