The modules I'm planning on using are the BlueSMiRF Silver Modem's shown here... http://www.sparkfun.com/products/10269.
I got one of them to work successfully but I want to make sure I can use two within the same area before I buy another one.
Yes. They aren't completely totally identical. They have different MAC addresses, same as two of the same network cards.
  • \$\begingroup\$ NO doubt the correct answer \$\endgroup\$
    – Piotr Kula
    Nov 23, 2011 at 0:08
  • \$\begingroup\$ @ppumkin, can you elaborate? \$\endgroup\$
    – Kortuk
    Nov 23, 2011 at 2:15
    \$\begingroup\$ @Kortuk- No Doubt - If i answered this thread my answer would be the same the correct answer imply that the answer can not get any better- deserves an up vote and most likely will be accepted as the only answer. \$\endgroup\$
    – Piotr Kula
    Nov 23, 2011 at 8:59
    \$\begingroup\$ +1, the only thing I would add is that some network devices/chips require the MAC id to be provided by hardware separate from the device. I'm not familiar with BlueSmirf \$\endgroup\$
    – kenny
    Nov 23, 2011 at 9:16
