I'm thinking of buying a DC Motor to play with. I'm wondering is there any way to pass a wire up to electronics spinning on the shaft?
I'd love to pass 4 wires (vcc, dcc, clk an data) lines from electronics sitting next to the motor up to some electronics being rotated by the motor.
I'm wondering if there is a connector of some kind that would let me do such a thing.
  • \$\begingroup\$ A motor shaft is solid. \$\endgroup\$
    – Alex
    Commented Apr 6, 2016 at 21:37
Yes. You are looking for a 4-pole slip-ring.
If you want the motor shaft to pass through the slip-rings you will need a hollow version.
Figure 1. Hollow slip-ring.
  • \$\begingroup\$ So this is just about what I would want. On the other hand I can't find anyplace that sells them. \$\endgroup\$
    – Justin808
    Commented Apr 7, 2016 at 4:40
  • \$\begingroup\$ You'll have to try harder! If you're on a tight budget then look up "DIY slip-rings" on Google image search. \$\endgroup\$
    – Transistor
    Commented Apr 7, 2016 at 6:08
