i have a Bluetooth speaker that uses a single cel 3.7 2600 mah battery but the charger says is 19V and i have read that the max volts to charge 3.7 V is 4.2 V, so how is this possible? now im confused?
thanks for the help :)
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityi have a Bluetooth speaker that uses a single cel 3.7 2600 mah battery but the charger says is 19V and i have read that the max volts to charge 3.7 V is 4.2 V, so how is this possible? now im confused?
As brhans said, the 19 volt adaptor is not the charger, but the power supply. I do not claim to know why the heck they used a 19V supply to run a 3.7V charger, unless it is that it needs a smaller transformer. If you look inside the speaker you will find the actual charger, but it is probably integrated into the speaker's mainboard.
Audio amplifier designed to operate at less than 5 volt power supply can only be good enough for headphones. For portable speaker, the amplifier needs a higher voltage.
Inside the box there will be a boost converter to step up 3.7 lithium cell voltage to a higher voltage for the louder amplifier.
Thus, as the other answers suggested, the 19 volt is a standard computer power supply chooses to work as the PSU for this speaker. The actual lithium cell charger must be a buck power supply integrated inside the box.
