I've some problem using together TLL and CMOS integrated. I'm developing a project and only now I discovered that the two standards can create troubles together.
So I decided to use only TTL chips. Luckily I can also use HCT integrated, that are bot compatible with TTL and CMOS.
I'm not sure about compatibility only about one chip... the M48Z02 (datasheet). It is a 5V, 16 Kbit ZEROPOWER SRAM. In the datasheet it is also written:
Pin and function compatible with JEDEC standard 2 K x 8 SRAMs
Does it mean something about the compatibility with TTL technology?
If not, where can I find information about the compatibility between M48Z02 and TTL technology?
Any help you can provide will be really appreciated.
