I have Verilog's code. It is simulated correctly and synthesize too. I wanted to write.VCD(value change dumped) file.
I got from internet few command to generate VCD file as given below:
initial begin
$dumpfile ("invchn26.vcd"); // Change filename as appropriate.
$dumpvars(1, t.uut);
end
But have few amount of confusion:
1. The above lines will be written on the testbench. Am I right?
2. I have below files:
testbench: stimulus.v ,
the main file named F_E. it is instance by name call in stimulus file. like written as F_E call (a,b,CLK,x,y);
I wrote below lines in stimulus (testbench file) :
 initial begin
    $dumpfile ("crt.vcd"); // Change filename as appropriate.
    $dumpvars(1, stimulus.call);
    end
But its giving error. How DO I create .VCD file with verilog and xilinx. Please suggest hints.
  • \$\begingroup\$ The iSim simulator can write VCD files. There is the -vcdfile <vcd_file> command line option. \$\endgroup\$ – Paebbels Apr 13 '16 at 18:17
(I show an example on linux, the steps with new names to avoid mixing the names and modules with your filenames.)
If you have a file, let´s say, "counter.v", then you would write a testbench file, say "counter_tb.v" (for the sake of clarity, it is better to name the testbench file "something_tb.v" for the file "something.v"). In the testbench-file, you give the vcd file name, as you mentioned:
$dumpfile("counter.vcd")
$dumpvars(0, counter_tb)   <= Name of the testbench module
In the testbench file, there has also to be the include command for the module under test:
`include "counter.v"
 module
     counter_tb();
Then you would compile (on Linux):
iverilog -o counter counter_tb.v
Then this can be processed with the command
vvp counter
which produces the output-file "counter.vcd" which can be inspected by the command
gtkwave counter.vcd
If all the steps above where correct, there should be no complain
| improve this answer | |
  • \$\begingroup\$ I am using window operating system. What if we write $dumpvars(1, counter_tb)? \$\endgroup\$ – RO.BST Apr 11 '16 at 8:32
  • \$\begingroup\$ The argument "1" in the $dumpvars command says that only the listed variables and variables of listed modules will be dumped. "0" that all variables within the modules from the list will be dumped \$\endgroup\$ – Coliban Apr 11 '16 at 8:40
