A few thoughts:
I'm assuming the PSU is DC within the range of 0V - 30V. (i.e no negative or AC voltages)
I don't know much about Arduinos, but do you have to set the pin to an analogue input? (e.g. like you would have to an a PIC) I'm thinking maybe the analogRead routine takes care of it. Also is the ADC reference voltage set correctly? (I notice there is a Aref pin floating on your schematic)
EDIT - Aref pin:
Atmel say:
The reference voltage for the ADC (VREF
) indicates the conversion range for the ADC. Single
ended channels that exceed VREF
will result in codes close to 0x3FF. VREF
can be selected as
either AVCC
, internal 2.56V reference, or external AREF pin.
AVCC
is connected to the ADC through a passive switch. The internal 2.56V reference is generated from the internal bandgap reference (VBG) through an internal amplifier. In either case, the
external AREF pin is directly connected to the ADC, and the reference voltage can be made
more immune to noise by connecting a capacitor between the AREF pin and ground. VREF
can
also be measured at the AREF pin with a high impedant voltmeter. Note that VREF
is a high
impedant source, and only a capacitive load should be connected in a system.
If the user has a fixed voltage source connected to the AREF pin, the user may not use the other
reference voltage options in the application, as they will be shorted to the external voltage. If no
external voltage is applied to the AREF pin, the user may switch between AVCC
and 2.56V as
reference selection. The first ADC conversion result after switching reference voltage source
may be inaccurate, and the user is advised to discard this result.
So if the external reference is selected you need to apply a voltage to it. From your comment below it looks like this may be the case. Try connecting it to AVcc (or whatever you want the top of the ADC range to be)
You can optionally add a 100nF cap to ground to reduce noise if necessary also.
Is your 5V supply stable? Have you got bypass caps present? (mentioned but not acutally shown on schematic)
Is your PSU sharing ground with the Arduino? If not this could cause the issues you are seeing.
