Good day,
Need some help. Start to work with Synopsys Synplify. Import my Xilinx ISE project (fully work).
Try to run and receive - "No matching overload for to_integer" for this line
rgb(7 downto 0) <= color_lut(result_reg(to_integer(unsigned(x(2 downto 0))-1 )));
What can I do to adopt this piece for Synplify?
Just a guess: did You include numeric_std? Also Your code line seems to be wrong, because there are 5 opening ( and only 4 closing ) and no closing ;. You can try to_unsigned() later.
  • \$\begingroup\$ Yes, numeric_std included. >code line seems to be wrong - "copy pust bug" :) brackets are correct \$\endgroup\$
    – fpgaiua
    Nov 28, 2011 at 18:03
  • \$\begingroup\$ copy more correct code then :) \$\endgroup\$
    – Tomas D.
    Nov 29, 2011 at 6:37
Does it compile in a simulator? You often get more useful error message, and you should always simulate before synthesising. EDIT: Your comments indicate you have and it's fine.
XST is not always a good representation of correctness of code - it's VHDL is sometimes a little off-spec in interpretation.
I'd have thought you want something like this (with lots of extra whitespace for clarity of answer, I'd not usually write it like this in source-code). You never know, Synplify might be happier with this version:
rgb(7 downto 0) <=
    color_lut(
        result_reg(
            to_integer(
                unsigned(
                    x(2 downto 0)
                ) --close "unsigned"
             ) -- extra bracket here - you now have a signed integer you can subtract '1' from
            -1
        ) -- close result_reg index
    ); -- close colour_lut index
Otherwise, please give more details on the data types involved.
  • \$\begingroup\$ is that a copy/paste error? -- yes \$\endgroup\$
    – fpgaiua
  • \$\begingroup\$ >you should always simulate before synthesising -- yes, but in simulator (or after XST synthes) it's all right. \$\endgroup\$
    – fpgaiua
    Nov 28, 2011 at 18:22
  • \$\begingroup\$ Can you post more code then - what type are color_lut, result_reg and x? \$\endgroup\$ Nov 28, 2011 at 19:50
