AFAIU, PWM works as follows:
According to the value of the counter in the microcontroller, a square wave is generated at a designated output pin of the \$\mu C\$. The duty cycle of this square wave is determined by the previously set compare value of the counter and the current value of the counter.
So, at a given time, if the counter is, say, higher than the compare value, the square wave at the designated output will be at high voltage (\$V_H\$). Similarly, if counter is lower than the compare value, the square wave at the designated output will be at low voltage (\$V_L\$).
I have heard that we are able to simulate analog output using PWM. For example, if the duty cycle of the output square wave is, say 60%, then AFAIK, we treat the output signal as if it is \$ (V_H - V_L) * duty cycle\$ for the whole duration of that PWM period.
But how is this possible? In reality, a 60% duty cycle means that the output signal is fully at \$ V_H \$ for 60% of the PWM period and it is fully at \$ V_L \$ at the remaining 40% of the PWM period.
How are we able to treat the output signal as if it is \$ (V_H - V_L) * duty cycle \$ for the whole of the period?
