I am purchasing this power supply for a computer I am putting together.
http://www.mini-itx.com/store/information/picoPSU-160-XT.pdf
and while in discussion with a rep, they spoke about not overloading any rail, as I could damage the power supply; However it does mention
Overload protection Over load protection will be effected when either of the loads (+5V & +3.3V) exceeds > 150% Max Load.
but not the 12V rail....
it gives a chart with max current with the voltage which I understand Power = Current * Voltage, but how do I calculate how much each component uses, especially if it uses more than one "rail." i.e., a Molex uses a 5.5v and a 12v pin, so how would I know how much the 5.5v rail is using, and how much the 12v rail is using?
There is only one 3.3v, one 5v, and one 12v rail, correct?
Here is a breakdown of my components and their estimated power consumption.
Component Estimated Wattage
Intel Core i5-2400 3.1GHz Quad-Core Processor 11W - 95W
Noctua NH-L9i 57.5 CFM CPU Cooler 5W - 10W
Asus P8H61-I R2.0 Mini ITX LGA1155 Motherboard 7W - 30W
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory 9W - 9W
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive 2W - 10W
Noctua NF-A4x10 4.8 CFM 40mm Fan 1W - 5W
Total: 37W - 169W
NOTE: This build is not meant for heavy tasks, no gaming, no editing, but maybe light programming, so I HIGHLY doubt I would overload anything, but I 100% want to make sure.
Any advice on how to calculate my usage, tips to set me in the right direction, or even just a plain answer would be appreciated.
Thank you for your time.
  • \$\begingroup\$ I have a i5-3570K system. Measured at the power plug -- 40 to 70W normal usage, 135W running 100% 3.8GHzX4 CPU benchmark. Since all Core-i probably take the power from +12V with dedicated DC-converter, definitely more than 70W of the measured power is from the +12V to the CPU alone. These numbers are at the power plug, so the actual DC power is probably 80-90% of these. I hope these numbers give you some hints. \$\endgroup\$
    – rioraxe
    Apr 15, 2016 at 21:35
  • \$\begingroup\$ Interesting, thanks! I'm assuming no graphics at all or...? Your TDP is 77W, while mine is 95, so 18 TDP difference about. I'm actually looking at some other units now, but they are decent big... They would fit, but I wouldnt be able to add many other perifs :(. \$\endgroup\$
    – XaolingBao
    Apr 16, 2016 at 6:12
Your fans and CPU cooler will run from +12. All the others will run from various voltages derived from either 3.3 or 5 volts, and without the detailed specs, you cannot tell the current levels at any voltage.
However, since your computed max power is 169 watts and the supply is only rated for 160, regardless of how it's divvied up you're probably in trouble. That's not to say it won't work, necessarily, since it's entirely possible that not all the components will require maximum power and at the same time.
But it's probably not a good idea trust this. Murphy's Law applies.
  • \$\begingroup\$ Thanks for the infomration. What "detailed specs" would I need? For each component? As for the max power, that's full load, and since I highly doubt I would EVER get to full load, wouldn't I be fine? One person said I would most likely never get above 120watts used. I was also looking to pick up a kill-a-watt meter to read the power consumption. I understand your comment about ":Murphy's Law" but that's what we are trying to avoid. I was assuming the biggest issue here would bet he processor at 95W, but I'm not sure if that would hurt the rail(s) or not? \$\endgroup\$
    – XaolingBao
    Apr 15, 2016 at 2:25
  • \$\begingroup\$ Also, since the important parts (according to you) run on 3.3v/5v, then wouldn't they be safe by the built in overload protection, but not the 12v rail? I'm not sure how safe it is, is the issue. I will contact them more and inquire. \$\endgroup\$
    – XaolingBao
    Apr 15, 2016 at 2:41
  • \$\begingroup\$ "What "detailed specs" would I need? For each component?" Yes. "As for the max power, that's full load, and since I highly doubt I would EVER get to full load, wouldn't I be fine?" Despite what you say, you do NOT understand Murphy's Law. "Whatever can go wrong, will." If you doubt that you will EVER get full load on your power supply..... \$\endgroup\$ Apr 18, 2016 at 16:01
Yours is a problem faced in the power industry and by me as I try to ensure that I select a suitable power supply for my PC build. What I'm about to say seems like a tangent, but its a very good analogy. Electricity equipment installed in a building must be rated for the peak demand less some demand factors; if all the loads operate at once and is above the rating, then overtime, heat builds up with resultant effects of personnel safety and property damage.
With a PC supply, same thing, if loads exceed rating, bad things can happen: voltage levels drop due to increased current flow. Some devices akin to resisters simply have current also decrease, inductive loads may try to maintain their power level thus current might increase. Will these effects damage your PC components? Maybe, but if your computer shuts down, at the very least you have inconvenience! And, by the way, the power supply protections are meant to protect the power supply; any incidental "protection" to the PC components and the extent of that should really be thought of as incidental.
Now talking about loads not operating fully at the same time is what electrical utility companies ponder. Electrical utilities take into account load diversity, because statistically speaking (and practically speaking), when you have hundreds and thousands of similar loads fed by the electrical system, you're going to have a load profile that is far below merely adding up all the loads. It's economically unfeasible to size utility company lines based on total loads and would be bad engineering practice, but again, you can't do that inside buildings due to risks to humans and threat of fire and other property damage (and you just don't have the same diversification of loads to allow that anyway).
With the PC power supply you have to be practical and utilize risk management. I want to know my total amperage on the 3.3, 5, and 12 volt rails so I know the power supply provides what my computer needs, and not leave it to chance that maybe all the components won't draw power at the same time. If you have 10 USB ports (which I have) there is just no way I will be using them all at the same time; I'll still want to know the power I may need for each, but I'm not going to upsize my power supply now so that 15 years from now I can use 8 of those ports at once instead of the three or four I can imagine using over the next years or two.
In short, unless you know the load profiles of each component (average load, peak loads) and when the loads of each component will or will not coincide). I would think protecting my computer investment by ensuring all loads at each voltage could be accommodated rather than just leaving it to chance. I'm gathering documentation on all devices for my build. Someone stated most power is derived from the 12V rails by the motherboard, so hopefully I can verify the accuracy of that statement. I'm not willing to risk my investment on "what somebody said!"
