I am building a power supply using an ATX powersupply. There are several wires for each: red for +5V, Yellow for +12V ans so on. The instructions I've seen instruct you to bundle the same colored wires and twist their ends together and then solder them to a binding posts.
I really don't want to do it this way because it is untidy and looks unprofessional. I was hoping to bring all the like wires together and connecting them to a terminal strip and from that strip have a heavier gauge wire that connects to their respective binding post.
Is there anything wrong with doing it this way? Is thereba best practices for auch wiring? Thanks.
