What is the meaning of standard discharge current mentioned on the datasheet of lithium batteries. Does it represent the maximum current load can take or it represent the instantaneous current battery can provide
  • \$\begingroup\$ Try linking to a data sheet. \$\endgroup\$
    Apr 15 '16 at 11:47
  • \$\begingroup\$ Added the datasheet screenshoot. Battery is CR2477N \$\endgroup\$ Apr 15 '16 at 11:50
  • \$\begingroup\$ How about a link to the data sheet? \$\endgroup\$
    Apr 15 '16 at 11:51
  • \$\begingroup\$ mouser.com/ds/2/346/CR2477N_v06-1943.pdf \$\endgroup\$ Apr 15 '16 at 11:52
  • \$\begingroup\$ Thank you @Andyaka for answering. I got answer to this question. \$\endgroup\$ Apr 20 '16 at 4:08
If you look at the graphs for performance you will see that best cell capacity for various loads implies a minimum load resistance of about 3 kohm. Much lower than this and cell capacity drops from about ~900 mAh potentially down to ~600mAh at 1k loading. These approximately correspond to currents of 1mA (3k load) and 2.5mA (1.2 k load) and approximately tie in with the "standard" and "max" discharge currents: -
The battery capacity is stated at 950mAh .This occurs at a discharge current of 1mA. You can draw less and the battery capacity may not be 950mAh .You are safe to draw up to 2.5mA but the battery capacity will probably be less than 950mAh . Do not draw more than 2.5 mA .
