I'm trying to design an electronically toggled switch(one single switch turning an LED on and off) using a T-Flip Flop(a 74HC73, to be precise). I believe I've connected all the inputs and outputs properly, yet, when I'm sending a clock pulse, the output is not getting toggled.
Please take a look at the circuit and try to figure out the problem:
Here's what the circuit is like on paper:
I think it is worthy to mention here that I haven't tried the circuit in reality yet, but, the Autodesk Simulator(which is pretty accurate) is not giving appropriate results. So, I believe the problem is with the circuit only.
Thank you for your time!
