-2
I am writing a program for a 16-bit ripple carry adder and stumbling a little at the end. When I run my code (which includes negative numbers), it's doing the math right, but giving me all positive answers. For instance: -59 + -16 is showing up in console as 65477 + 65520 = 65461 instead of -59, -16, -75(which I know is correct for unsigned binary arithmetic). How do I get console to show me the appropriate negative numbers?
Here's my code if necessary:
module adder ();
    reg[15:0] a, b;
    wire[15:0] s;
    wire c_out;
    fulladder FA0(c1, s[0], a[0], b[0], 1'b0);
    fulladder FA1(c2, s[1], a[1], b[1], c1);
    fulladder FA2(c3, s[2], a[2], b[2], c2);
    fulladder FA3(c4, s[3], a[3], b[3], c3);
    fulladder FA4(c5, s[4], a[4], b[4], c4);
    fulladder FA5(c6, s[5], a[5], b[5], c5);
    fulladder FA6(c7, s[6], a[6], b[6], c6);
    fulladder FA7(c8, s[7], a[7], b[7], c7);
    fulladder FA8(c9, s[8], a[8], b[8], c8);
    fulladder FA9(c10, s[9], a[9], b[9], c9);
    fulladder FA10(c11, s[10], a[10], b[10], c10);
    fulladder FA11(c12, s[11], a[11], b[11], c11);
    fulladder FA12(c13, s[12], a[12], b[12], c12);
    fulladder FA13(c14, s[13], a[13], b[13], c13);
    fulladder FA14(c15, s[14], a[14], b[14], c14);
    fulladder FA15(c_out, s[15], a[15], b[15], c15);
    initial begin
$monitor ($time, "a = %d, b = %d, s = %d, cout = %b", a, b, s, c_out);
            a=0; b=0;
            #100 $display ($time);
            #900 a=-10; b=100;
            #900 a=63; b=127;
            #900 a=15; b=95;
            #900 a=-32; b=79;
            #900 a=-59; b=-16;
            #900 a=1000; b=2001;
            #900 a=-3210; b=15;
    end
endmodule
/* 1 Bit Full adder module */
module fulladder (cout, si, ai, bi, cin);
    parameter delay2=1, delay3=2, delay4=3;
    input ai, bi, cin;
    output cout, si;
    and #delay3 (si1, ~ai, ~bi, cin),
                (si2, ~ai, bi, ~cin),
                (si3, ai, ~bi, ~cin),
                (si4, ai, bi, cin);
    or #delay3 (si, si1, si2, si3, si4);
    and #delay2 (ci1, ai, bi),
                (ci2, ai, cin),
                (ci3, bi, cin);
    or #delay3 (cout, ci1, ci2, ci3);
endmodule
This is Verilog, not VHDL.
Declare your reg as signed and you will get the correct results.
reg signed [15:0] a, b;
