Basically what I am after is some sort of a circuit which will amplify higher voltage signals, but possibly dampen lower voltage signals, in order to make a wider separation between high and low voltage. This is just for a little DIY project I am working on at home, and basically it would be comparable to setting your audio equipment to "Theater" mode vs. "Quiet" mode. Would this be easily accomplished with a fairly simple circuit, or am I trying to go after something far too complex for a beginner?
What would be the name of a circuit similar to what I am attempting to build?
    \$\begingroup\$ Yes, an expander. That seems to be exactly what I am looking for is a "Dynamic Range Expander" circuit. \$\endgroup\$ – Sean Nov 29 '11 at 4:17
6
What you are describing is an expander. This performs the opposite function of a compressor.
Basically, it is a amplifier (or simple attenuator, see below) circuit set up so that the gain is controlled by the incoming signal level. There are various ways of implementing this in a circuit, from simple to very complex. Here is an example of about the simplest compander (compressor/exander) circuit using a light dependent resistor and LED to control the attenuation:
Basic Compander
Here is the page of articles/schematics this came from which includes the explanation of the circuit and various other similar circuits. Google will turn loads more up.
It sounds like you're after some kind of expander circuit, which is half of a compander. There are many example circuits available online, with a great deal of them around the NE571 or NE572.
    \$\begingroup\$ How about you add an example to your answer? We want to be the source of content not a place to find links. This helps down the road when people find this question from searching the web and might end up finding all of your links to be dead. \$\endgroup\$ – Kellenjb Nov 29 '11 at 15:41
