-1
I have at car usb charger. It has 2 ports and is rated 2.1A when one port is used and 1A when both ports are used. I attached samsung tablet (N8000) witch requires 2A output. So, tablet isn't charging. Then i plugged my phone (S5 neo). I drive around with waze turned on (about one hour). My battery does not charged. It even discharge by about 3 or 5 percents. I tried both ports.
Then i found my old 1A charger with single port. That charger charged my phone, with waze turned on. From 80% it goes to 100% within one hour. In both cases i used the same cable.
So - how i can test charger output amperage? Do i need special equipment or it can be done with multimeter?
Edit: How I can test if charger really can supply rated amperage? So, how to test its limits ?
Edit2: Found this article: http://www.deeptronic.com/variable-dummy-load-for-power-supply-testing/ and I try to build that.
closed as off-topic by uint128_t, Asmyldof, Adam Haun, PeterJ, Daniel Grillo Apr 19 '16 at 11:18
This question appears to be off-topic. The users who voted to close gave these specific reasons:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – uint128_t, Adam Haun, Daniel Grillo
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Asmyldof, PeterJ
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ The problem may also be insufficient voltage out of the "charger". \$\endgroup\$ – DoxyLover Apr 18 '16 at 18:56
The issue may also be that the "charger" (actually power supply) is putting out insufficient voltage, instead of insufficient current.
If you don't want to build something like @transistor has described, there are many commercial products out there that will connect between a USB host port or power supply and the cable and display both voltage and current drawn. Search for "USB ammeter" to find them.
Figure 1. Monitoring USB current.
You can use a USB extension lead or cut into one of your existing leads. Add the multimeter set to 'DC A' in series with the red lead.
The D+ lead is actually white. Yellow shown in Figure 1.
  • \$\begingroup\$ With this I can test how much phone is taking. Right? \$\endgroup\$ – Guntis Apr 18 '16 at 18:08
  • \$\begingroup\$ All power to the device connected will be drawn through the red wire, so yes. \$\endgroup\$ – Transistor Apr 18 '16 at 18:18
    \$\begingroup\$ There are also many commercial products available to do the same thing, plus show the voltage at the same time. Search for "usb ammeter" to find them. \$\endgroup\$ – DoxyLover Apr 18 '16 at 18:55
  • \$\begingroup\$ @DoxyLover, that is what I am looking for. Can You write it as answer? \$\endgroup\$ – Guntis Apr 19 '16 at 4:26
