Is there a function to read the Vrefint_cal in Cubes HAL libraries? I'm using the F3xx. I'd like to measure the supply voltage of the micro. The formula given in the reference manual is:
\$ \Large VDDA = 3.3V \times \frac{Vrefint_{cal}}{Vrefint_{data}} \$
I've been searching through HAL (cube) and couldn't find a method to return the Vrefint_cal. The datasheet says that it is at 0x1FFF F7BA - 0x1FFF F7BB, but I find it silly that there wouldn't be a method to read it directly.
One simple way is the following:
#define VREFINT_CAL_ADDR    0x1FFFF7BA
uint16_t vrefint_cal;                        // VREFINT calibration value
vrefint_cal= *((uint16_t*)VREFINT_CAL_ADDR); // read VREFINT_CAL_ADDR memory location
Or a more general is to simply create a pointer and assign 0x1FFFF7BA to it, and then the rest is the same.
#define VREFINT_CAL_ADDR ((uint16_t*)((uint32_t)0x1FFFF7BA))
And then, for example:
Vdd = 3300*(*VREFINT_CAL_ADDR)/ADC_raw;
Where Vdd and ADC_raw are uint16_t.
More info here: https://letanphuc.net/2016/07/stm32f0-adc/
