I'm an absolute beginner with LTSpice; my first test circuit uses a few D flip-flops: four of them as clock dividers (to divide the clock frequency by 16), and then 3 as delay blocks (to delay the f/16 signal by three clock periods).
Below is the saved .asc file.
The thing is, when I run the simulation the "delayed" signal is not really delayed --- it is an exact copy of the signal at the input of the first delay flip-flop. Specifically, the Q output of A3 (which is connected to the D input of A4) and the Q output of A7 are identical and perfectly aligned (i.e., without any delay between one and the other).
Am I doing something wrong, or is LTSpice doing something wrong?
Thanks!
Contents of D-flipflops.asc file:
Version 4
SHEET 1 1448 680
WIRE -144 -64 -368 -64
WIRE 80 -64 -128 -64
WIRE 304 -64 96 -64
WIRE 528 -64 320 -64
WIRE -368 48 -368 -64
WIRE -336 48 -368 48
WIRE -160 48 -176 48
WIRE -128 48 -128 -64
WIRE -112 48 -128 48
WIRE 64 48 48 48
WIRE 96 48 96 -64
WIRE 112 48 96 48
WIRE 288 48 272 48
WIRE 320 48 320 -64
WIRE 336 48 320 48
WIRE 752 48 496 48
WIRE 1008 48 912 48
WIRE 1264 48 1168 48
WIRE -160 64 -160 48
WIRE -128 64 -160 64
WIRE 64 64 64 48
WIRE 96 64 64 64
WIRE 288 64 288 48
WIRE 320 64 288 64
WIRE -336 96 -368 96
WIRE -144 96 -144 -64
WIRE -144 96 -160 96
WIRE -128 96 -128 64
WIRE -112 96 -128 96
WIRE 80 96 80 -64
WIRE 80 96 64 96
WIRE 96 96 96 64
WIRE 112 96 96 96
WIRE 304 96 304 -64
WIRE 304 96 288 96
WIRE 320 96 320 64
WIRE 336 96 320 96
WIRE 528 96 528 -64
WIRE 528 96 512 96
WIRE 752 96 720 96
WIRE 1008 96 976 96
WIRE 1264 96 1232 96
WIRE -368 208 -368 96
WIRE 720 208 720 96
WIRE 720 208 -368 208
WIRE 832 208 720 208
WIRE 976 208 976 96
WIRE 976 208 832 208
WIRE 1232 208 1232 96
WIRE 1232 208 976 208
WIRE 832 400 832 208
FLAG 832 480 0
SYMBOL Digital\\dflop 192 0 R0
SYMATTR InstName A2
SYMBOL Digital\\dflop 832 0 R0
SYMATTR InstName A4
SYMBOL Digital\\dflop 1088 0 R0
SYMATTR InstName A5
SYMBOL Digital\\dflop 1344 0 R0
SYMATTR InstName A7
SYMBOL voltage 832 384 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value PULSE(0 5 0 5n 5n 0.5u 1u 20)
SYMBOL Digital\\dflop -32 0 R0
SYMATTR InstName A1
SYMBOL Digital\\dflop 416 0 R0
SYMATTR InstName A3
SYMBOL Digital\\dflop -256 0 R0
SYMATTR InstName A6
TEXT -370 500 Left 2 !.tran 0 30us 0
6
If you go to the LTspice help and navigate to "Special Functions" you'll see a list of parameters that can be selected for the digital components, including the Dflop.
Your shift register didn't work because it had no output rise or fall time associated with it, so everything was happening all at once!
Also, the digital stuff defaults to a Vcc of 1 volt.
I've redrawn your schematic so everything starts cleared, Vcc is 5 volts, and put some delay into the Dflops, and now it works. :)
If you right-click on any of the dflops, that'll bring up the attribute editor, which will show their edited (non-default) parameters, specifically:
SpiceLine = Vhigh 5 Trise 10n
and will allow you to modify any of the component's editable attributes.
Here's the schematic and the plot, which I edited to look like a timing diagram:
enter image description here and here's the circuit list:
Version 4
SHEET 1 1732 752
WIRE 48 -144 -256 -144
WIRE 352 -144 48 -144
WIRE 656 -144 352 -144
WIRE 864 -144 656 -144
WIRE 1104 -144 864 -144
WIRE 1360 -144 1104 -144
WIRE 1616 -144 1360 -144
WIRE -128 -64 -368 -64
WIRE 176 -64 -64 -64
WIRE 480 -64 240 -64
WIRE 784 -64 544 -64
WIRE 864 -64 864 -144
WIRE -256 0 -256 -144
WIRE 48 0 48 -144
WIRE 352 0 352 -144
WIRE 656 0 656 -144
WIRE 1104 0 1104 -144
WIRE 1360 0 1360 -144
WIRE 1616 0 1616 -144
WIRE -64 48 -64 -64
WIRE -32 48 -64 48
WIRE 144 48 128 48
WIRE 240 48 240 -64
WIRE 272 48 240 48
WIRE 448 48 432 48
WIRE 544 48 544 -64
WIRE 576 48 544 48
WIRE 1024 48 736 48
WIRE 1280 48 1184 48
WIRE 1536 48 1440 48
WIRE 1728 48 1696 48
WIRE -128 96 -128 -64
WIRE -128 96 -160 96
WIRE -32 96 -128 96
WIRE 176 96 176 -64
WIRE 176 96 144 96
WIRE 272 96 176 96
WIRE 480 96 480 -64
WIRE 480 96 448 96
WIRE 576 96 480 96
WIRE 784 96 784 -64
WIRE 784 96 752 96
WIRE 1024 96 992 96
WIRE 1280 96 1248 96
WIRE 1536 96 1504 96
WIRE 992 208 992 96
WIRE 992 208 -368 208
WIRE 1248 208 1248 96
WIRE 1248 208 992 208
WIRE 1504 208 1504 96
WIRE 1504 208 1248 208
WIRE -256 288 -256 144
WIRE 48 288 48 144
WIRE 48 288 -256 288
WIRE 352 288 352 144
WIRE 352 288 48 288
WIRE 656 288 656 144
WIRE 656 288 352 288
WIRE 1104 288 1104 144
WIRE 1104 288 656 288
WIRE 1360 288 1360 144
WIRE 1360 288 1104 288
WIRE 1616 288 1616 144
WIRE 1616 288 1360 288
WIRE -368 336 -368 208
WIRE -256 336 -256 288
WIRE -368 448 -368 416
WIRE -256 448 -256 416
WIRE -256 448 -368 448
WIRE -368 512 -368 448
FLAG -368 512 0
FLAG 864 -64 0
SYMBOL voltage -368 320 R0
WINDOW 3 86 297 Invisible 2
SYMATTR InstName V1
SYMATTR Value PULSE(0 5 1u 5n 5n 0.5u 1u)
SYMBOL voltage -256 320 R0
SYMATTR InstName V2
SYMATTR Value PULSE(0 5 0 50n 50n 100n)
SYMATTR InstName A1
SYMATTR SpiceLine Vhigh 5 Trise 10n
SYMBOL Digital\\dflop 48 0 R0
SYMATTR InstName A2
SYMBOL Digital\\dflop 352 0 R0
SYMATTR InstName A3
SYMBOL Digital\\dflop 656 0 R0
SYMATTR InstName A4
SYMBOL Digital\\dflop 1104 0 R0
SYMATTR InstName A5
SYMBOL Digital\\dflop 1360 0 R0
SYMATTR InstName A6
SYMBOL Digital\\dflop 1616 0 R0
SYMATTR InstName A7
TEXT -352 480 Left 2 !.tran 0 30us 0
  • \$\begingroup\$ A long time ago, I helped a friend fix a cicuit that uses a flip-flop composed of two 4000-series (CMOS) gates. It didn't work because the chip was "too fast" - adding resistors and capacitors into the lines feeding the output signals back to the respective gate inputs fixed it. Even real circuits can be too fast for common assumptions to work ;-) \$\endgroup\$
    – zebonaut
    Apr 19, 2016 at 8:31
  • \$\begingroup\$ Did I understand correctly? Do I have to go through HELP to get to "Special Functions"? I'm using LTSpice on Linux through Wine 1.6, and the help does not seem to work. The Help topics shows me the filesystem (well, a "File Browser"). If I navigate to the c:\Program Files\LTC\LTSpice.... and click on the LTSpiceIVHelp.chm, then it opens another "File Browser". Do I really need to run it natively on Windows? (I know this may be a Wine question, rather than an LTSpice question, but maybe some of you guys have run into this issue and could share some tips?) \$\endgroup\$
    – Cal-linux
    Apr 19, 2016 at 20:52
  • \$\begingroup\$ Never mind --- so easy to reverse engineer :-) Just looked up the file dflop.asy, opened it with a text editor and noticed/guessed that I just had to add a line SYMATTR SpiceLine Trise=5n Tfall=5n Td=5n --- worked like a charm! :-) \$\endgroup\$
    – Cal-linux
    Apr 19, 2016 at 20:59
  • \$\begingroup\$ @Cal-linux What you did was change the symbol for any DFLOP instance from then on... You should follow Peter Smith's suggestion. \$\endgroup\$ Aug 30, 2016 at 7:05
In addition to EM Fields answer, it is possible to set the timing and voltage parameters from the device attributes dialogue:
FF Attributes
Here, I have set Vout high and low for a 3.3V system, the input switching threshold to 1.5V; it defaults to (Vhigh - Vlow) / 2 which may not be what you want, output rise and fall times to 5ns and propagation delay to 5ns.
